Rota Grids in 15x8??
  • wakdog
    • 223
    becuase there is less backspace with low offset, this brings the spokes of the wheel closer to the hub.
    With my Grid V 15x8 +0 they touch on the backside of the wheel approx where ive marked
    , on the inner part of the caliper.
    by grinding a small amount off the edge of the caliper and smoothing it, along with a 3mm spacer i should be able to run them no problems.
    90 318i M62B44 OBD1
    02 530i Touring (Airlift 3P)
    • The Humjet
      • Jun 2010
      • 528
      If I get these I plan to run a 5-10mm spacer at the back to give it the poke to match the front guards. And then a grind at the caliper where you marked in the photo. I really want to avoid spacers at the front, I don't want to be shelling out more money for 4 spacers 2 is enough for my budget . But if it has to be done then i'll have to note the bullet because I really like these wheels along with the rota shakotans 15X9 et0 that funfgun is running but those wheels need more mucking around to get it to fit but with some negative camber and lots of stretch would look titties
      • FunfGan
        • Jan 2011
        • 4958
        Wakdog Those wheels look sick, can't wait to see em mounted!
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • wakdog
          • 223
          i see they do the shakotan in a 15x8 +0, i might have to get a set for my 318is if i can get the grids over the caliper easily enough on the 2.7 car. the 15x9s are probably too extreme with how low id need to go to have them look good and with how shit my local roads are :(
          90 318i M62B44 OBD1
          • Mr Two
            • Jul 2008
            • 590
            Wow, didn't take long for Rota to rip the design for the new TE37Vs! They even used the same letter designation.
            • DuMa
              • 1101
              i like it. what centerbore do you need to be hubcentric?
              • graphikg
                • Jan 2008
                • 1614
                Where can you get these?
                • Eydreeyun
                  • 584
                  ^^ 18racing.com
                  I tried it, front sticks way too much for my liking. Here's a photoshop:
                  • graphikg
                    • Jan 2008
                    • 1614
                    So I'm guessing these won't clear rx7 calipers.
                    • 619E30
                      • 1753
                      Hmmmm, that's a lot of poke in the front
                      Originally posted by audiquattrot
                      bimmers b4 b*tches....remember that.
                      1990 Alpinweiss 325i - secret 500whp build
                      2000 Audi S4 B5 Laser Red
                      1990 Nissan 240sx - Drift Missile
                      2006 CBR600RR
                      • grippymonkey
                        • Jun 2011
                        • 759
                        +0 plus spacers in front to clear brakes will push you out quite a bit if you don't have camber adjustment to dial it back in...
                        GRIPPY'S*GARAGE
                        • 619E30
                          • 1753
                          True, and the photoshop can't be too accurate.
                          2006 CBR600RR
                          • The Humjet
                            • Jun 2010
                            • 528
                            Sorry too shit all over this thread, but I heard on the track that rota wheels break appart pretty easily. I love the look of their low offset wheel range but if I'm gonna be drifting every now and then on those drift practise nights I don't want my new investment to break appart easily
                            • Rau
                              • 449
                              And who exactly races with Rota's?
                              Originally posted by RUFFLZ
                              #BANDISNIGGA
                              Originally posted by Wh33lhop
                              Why the fuck would you ever put a drink up there? If you ever have a drink to hold, just put it between your legs. You know, where your balls used to be before you had a girlfriend.
                              • The Humjet
                                • Jun 2010
                                • 528
                                A friend of mine who regularly drifts his car told me he saw it in a thread of a rota wheel centres literally separating from the lips when taken to the track driving over stuff like ripple strips.
                                Here is a link I gathered myself but that's all I could find, every other thread that spoke about these wheels always refered to this incident.
                                http://forums.beyond.ca/showthread/t-10242.html
                                Maybe it was a one off
