Can't stop rubbing.
  • lolcantturn
    • 4588
    Can't stop rubbing.
    I'm running 205/55/15 proxes on 15x8 Diamond Racing steelies in the rear of my car, with stiff IE3 springs. I can't for the life of me get the passenger side of my car to stop rubbing, my driver side trailing arm bushings are shot so I have enough camber there to prevent rubbing, but my passenger side ones are good and I'm rubbing moderately bad. Already have a etching on the sidewall of the tire carved in the form on the inside of the fender.
    My fenders are just about as rolled as I can get them. I need this car ready to take 300lbs in the rear by Saturday morning as I'm going on a roadtrip with friends. Any ideas?
    Originally posted by TSI
    OEM+
  • E30SPDFRK
    • 5715
    Roll it more. Did you take out the undercoat behind the lip when you rolled it?
    Byron
    Leichtbau
    • z31maniac
      • 17566
      Those big rubber chunks people throw in between springs.
      Or order some stiff rate, long springs from GC and throw them in the back.
      www.gutenparts.com
      • ak-
        • 12422
        Options!:
        Roll more
        Stiffer spring/coil
        Spring pads
        Replace rtab/rsfb
        Different wheels
        Don't invite the fat friend
        The cheapest option is obvious
        1991 325iS turbo
        • CHIF8008
          • 3447
          ^^^hahaha
          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
          -The Beauty in the Tragedy-
          MECHANIC SMASH!!- (you all know you do it)
          Got Drop?? ;-)
          But of course
          E30s are know to be notoriously really really really ridiculously good looking
          • MG325i
            • Jan 2007
            • 805
            too tall of a tire! 55's is too tall! need to be at the most 50's. that should take away some rubbing issues also
            E30 325I > SOLD
            E30 318IS > SOLD
            E39 530I > SOLD
            EP3 > SOLD
            95 M3 > SOLD
            97 M3 > DD
            • E30m42cab
              • Aug 2009
              • 190
              Extra set of spring pads in there might just do the trick, and it'll take very little time to do it.
              • Mauisnow13
                • 37
                I was looking at running 205's on a 16x8 with 0 offset and found that only 205/40/16's would satisfy my needs. Not sure if you're as low as I am, but I would look at getting a lower profile tire. Something like a 205/45/16 should be ok I'd think. Doesn't sound like you're super low.
                As for a quick fix, throw in a few extra spring pads in the rear. Just head to a junk yard and look for them above and below the stock rear springs. Take them and put them over your current ones so there are 2 or 3 or however many you find necessary. Cheap solution that doesn't take long.
                • Stephen
                  Шлем ишака
                  • 10774
                  less tire, also progressive springs will allow for more ass shaking and rubbing compared to linear
                  • JTapper
                    • Sep 2009
                    • 847
                    I thought this was a thread about chronic masturbation.
                    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                    • Massimo
                      • Jan 2008
                      • 3207
                      I have the same problem I find the shemale......
                      Wait What?
