What's the best way to make 16x7 ET45 ASA AR1 wheels with 205/45/16 tires fit on a stock suspension 1986 325e?
I'm pretty sure that I'll need spacers for the front, but I'm not sure what the best size would be? Not sure if I need spacers for the rear?
Will I need hub centric rings? I believe the hub bore is larger than 57.1mm.
if I get spacers with a hub centric lips, will I still need rings?
Thanks!
Thanks!
