Tire Rack and tire size dilemma
  • e30nut
    • 116
    Tire Rack cancelled my order after I tried purchasing a set of TR Motorsport C1 (15x8, ET20) wheels with a set of 205/55 R15 tires. When I called the customer service rep they said that they won't put a 205 on anything greater than 7.5".
    OK, I know they're a tad "undersized" and maybe I'm approaching this all wrong but from what I can tell from other's photos I was certain that 205/55/15 would be a good size to avoid rubbing issues with this wheel combination. I have stock suspension at the moment, but I'm planning on either GC coils or H&R Race with drop hats.
    Question: Do I go with 225 or find someone else who will mount a set of 205s?
    Originally posted by supkev
    I'm thinking vinyl my whole car. Matt black or gray.
    Originally posted by straight6pwr
    I'm thinking of hitting you in the face. Fist or karate-chop.
  • e30nut
    • 116
    Well, I decided to go with the 225s. kamotors is running the same wheel with 225/50s:
    • grippymonkey
      • Jun 2011
      • 759
      good stuff...
      205 is no problem on a 8" though
      GRIPPY'S*GARAGE
      • DuMa
        • 1101
        Originally posted by e30nut
        Tire Rack cancelled my order after I tried purchasing a set of TR Motorsport C1 (16x8, ET20) wheels with a set of 205/55 R15 tires. When I called the customer service rep they said that they won't put a 205 on anything greater than 7.5".
        they have 16x8? i tried doing a quick search on tirerack and they only have at the biggest/widest is at 15x8 +20. where are you seeing 16x8 TRM CR1s?
        • Holland
          • Nov 2008
          • 7212
          You could have ordered them, and on checkout not specify what the tires are for, unless they are mounting them, then that would make sense. When I went to order 225/45's they said they would be a bit undersized.
          Originally posted by DEV0 E30
          • KVF
            • 297
            He meant 15... They don't have a 16 inch offering of C1's for us. :(
            • IminDiegoTriick
              • Oct 2009
              • 1564
              I had this problem to when they got my order wrong and I called them in on it. & when they asked what the purpose was to get a 205/45/16 on a 16x9, I told them It was too run a bit of stretch. Then the rep turned into megatron about how he couldnt sell me it now that I said I wanted to stretch the tire. Then a lil bit of argueing then I re ordered. whatever
              Fast life fuck slow..Low life for life
              Let the mix flow..Let the night flow
              I'm so gone ✗ ♥ O
              • DuMa
                • 1101
                got my hopes up for nothing
                • e30nut
                  • 116
                  Typo, corrected.
                  • e30nut
                    • 116
                    I kind of understand their issue with a 205 tire on a 9" wheel, but on an 8" wheel?... come on Tire Rack.
                    • The Humjet
                      • Jun 2010
                      • 528
                      What is the reason behind not allowing stretched tyres. If its what the customer asked for then they should do it. 205 on an 8" is mild stretch any wheel/tyre shop should be able to do that with their eyes closed
                      • sweet6e30
                        • Feb 2011
                        • 531
                        lolz MEGATRON!!!
                        my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                        • e30nut
                          • 116
                          They claim it's a liability issue, that if there was a problem with the tire down the road that TR would be liable because the tire manufacturer only recommends a 7.5" wheel or less for that size.
                          • E30SPDFRK
                            • 5707
                            Many tire companys such as Falken and Toyo say that size on that wheel is no problem. Falken allows a 205/40 on an 8" wheel. What tires were you trying to buy?
                            Byron
                            Leichtbau
                            • e30nut
                              • 116
                              Kumhos, but it's moot because TR said they wouldn't mount that size from any manufacturer. Utterly stupid.
