16x9/10 +6 - Am i just being crazy?
  • Ant_e30
    • 292
    G'day all,
    In browsing for some wheels i've come across some used 16s for a good price. I want aggressive fitment and something different, and these definately fit the bill on both accounts.
    Having said that, they are:
    16x9 +6
    16x10 +6
    Yup, pretty dang crazy offets and widths for an E30! now i know some of you on here are running 9 +0 up front so i know it can be made to work. But a 10 +6 up back i dont know?
    This car is a slow project, but is meant to be my daily haha however i don't think i would run these wheels daily.
    Suspension will be coilovers (BC or GC).
    Anyone with fitment as aggressive as this who could comment would be great. i need to know if i can pull the trigger in the next day or so.
    cheers all,
    Ant
  • grippymonkey
    • Jun 2011
    • 759
    It can always be done. It is just a matter of the right stuff being done to make it fit. I would just suggest going ahead and aggressively pulling the fenders on all fours when you roll them. You will need some camber adjustment also if you want to dial in more negative camber to tuck the tires inside the fenders. That way you aren't poking massively outside the fenders. The right tire size will come into the equation also. You'll want to run some stretch that's for sure. I've seen 215/40/16 front and 225/40/16 rear on E30's with 16x9/10. If you are a little more brave a 215/40/16 can be done on the rear also, but I'd personally go with the 225/40/16 because the stretch will then look similar front and rear. It will also be an easier stretch, a little better for a daily driver, and most shops (at least in Socal) would be able to mount those tires easily.
    GRIPPY'S*GARAGE
    • M-technik-3
      • 18946
      No mention of early or late model chassis.
      • 87e30
        • Jul 2008
        • 5676
        I think your fenders are going to be so pulled/mangled that you will need to run that aggressive all the time.
        I just hate everyone.
        No need for discretion.
        • The Humjet
          • Jun 2010
          • 528
          I think more stretch on the tyres a needed. 225 on a 10" wheel is not enough stretch. Something like a 205/40/16. The guys putting 16X10 DR steelies on the back are running 195/40/16. But then again they're running a lower et0 offset than you will be doing. FunfGun is running a 205/50/15 on his 15X9 wheels. They poke out a fair bit at the front so some negative camber is definitely needed
          • Ant_e30
            • 292
            Thanks all for the input on this.
            M-Tech - i have the late model chassis, an 89.
            87e30 - this is a worry also. i hate those people that get wheels that just poke a little, then they flare out their arches so they end up sunken in by 10mm anyway. why even bother going aggressive in the first place!
            Humjet - yeah i have been trying to locate some pics of the people with the wide Steelies. I am not scared of stretch ,especially if i won't daily these wheels. I think you're right...i found a german site with people running some really aggressive offsets on rolled guards and the key seemed to be crazy stretch!
            I am tempted to bite the bullet and push the boundaries a bit...
            • FunfGan
              • Jan 2011
              • 4958
              You Won't
              15x10 +0 in the front,
              15x12 +10 in the rear.
              You won't.
              Go here be happy!
              Ratchet Garage e30 V8 build.
              • z31maniac
                • 17566
                195 on a 10"?
                He's also running 205s that are nearly square shouldered on an 8".
                www.gutenparts.com
                • M-technik-3
                  • 18946
                  There was a guy named Alex in the DC chapter that ran 16x9 square but his were et 15's. You are looking at some flairs to cover the poke and prevent the debris from getting all down the side of your car.
                  Think roster tails off your tires.
                  • The Humjet
                    • Jun 2010
                    • 528
                    195 on a 10"?
                    Believe me I've seen it done, yes its excessive stretch but that's what I heard is needed to fit low offset 10" wheels
                    Also also if your talking about funfgan's wheel fitment then they're a 15X9 et0 with a meaty sort of stretch, that's why they seem square shouldered
                    • Brandon12V
                      • 1318
                      it can be done but you'll have to stretch. a 225-40 would fit but good luck finding a decent tire in that size. you need to roll & pull. I've ran 17x10 et22 245-40's on late model at arches rolled & slightly pulled.
                      Originally posted by Ryan...
                      It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                      • penneroyal
                        • 209
                        Your not crazy at all. Another tire size suggestion: 9" 205 40's, 10" 215 40'S or 35's.
                        Know you must roll your fenders, obv. I think that setup would look great.
                        THE ACURA TL PROJECT
                        BUFF ENUFF? STYLE.OVER.COMFORT
                        DURTY 3ER///STYLE.OVER.COMFORT
                        • Blackout
                          • Apr 2011
                          • 4130
                          You are not being crazy.
                          You are being Hella Flush!:pimp:
                          » PARTS FOR SALE
                          » TRANSACTION FEEDBACK
                          • Tonys18t
                            • Sep 2009
                            • 943
                            This
                            PBMW Magazine. PVW Mag
                            Fender Rolling for dirt cheap in SoCal. Hit me up.
                            Check out my work...
                            http://www.r3vlimited.com/board/showthread.php?t=165114
