RX-7 brakes, vs-xx wheels,
  • canuckder
    • 82
    So im on ground control coils as low as they sit,
    And i just finished installing rx-7 calipers. I had kerscher carmonas on it, And they didnt clear.
    So i went out and bought 17x8/17x9 et.35 vs-xx. They are 5 lug, So i ordered adaptors that are taking forever.
    My question is, will these fit/clear? The offset will come down a et.15. same as the carmonas (which i ran a 2mm spacer in front, with grounded calipers)
    I was told i couldnt run anything more than a 215.40.17. So thats what i bought, but being a turbo'd m30. Im looking to put down some more power.
    So my second question is, If i got a pair of (blank). in size, 16x8 et.25, What size tire could I run? Could i fit a 225 or 235 / 45/16?
    picture of last years set up
    Uploaded with ImageShack.us
    Thanks guys!
  • canuckder
    • 82
    Anyone with any expeirence with
    17x8 17x9 et.15 with 215/40/17?
    • Ant_e30
      • 292
      VS-XX come in different brake clearances, this is called the Disc of the wheel. do you know which Disc the ones you got are? There is Hi, Mid and Low (and that refers to brake clearance).
      Edit - just checked the site for you on the brake clearance thing..
      A Disk - standard clearance
      O Disk - deep rim
      R Disk - big brake caliper
      • canuckder
        • 82
        hmm, Im hoping it fits.
        Thanks to e30rob, ill be able to let everyone know alot sooner.
        adaptors on thee way.
        • grippymonkey
          • Jun 2011
          • 759
          I would imagen they are going to fit. The 17x8 +35 will not have must of a disk and a medium sized hub. So I am guessing with a 20mm spacer they are going to clear no problem. I've seen several 17x8 +35 VS-XX and other sizes to in my day. The cool thing is you could get different lips down the road to make them wider also.
          Keep us posted.
          GRIPPY'S*GARAGE
          • canuckder
            • 82
            Keep us posted.
            That i will, I know most of what i says its all over the place.
            Last years set up 16x9 et. 15 all around, with 2mm spacer in front.
            17x8 et.15 in the front, with a 215.40.17 in the front. im more than positive it will fit. I was told not to run spacers with adaptors
            • z31maniac
              • 17566
              ^The adapters are still adding clearance.
              The 17x8 APEX wheels seem to be the right solution. Lots of clearance (everything but the MAssive Race kit I think), lightweight, affordable, and you can stuff a 235/40 or 245/40/17 on them.
              www.gutenparts.com
              • canuckder
                • 82
                ^^ im actually thinking of getting a set for the rears, just for the tire choices i can go with.
                • canuckder
                  • 82
                  Moment of truth tommorrow,
                  Adaptors are here, brakes were bled tonight. Coming off jack stands for the first time in 8 months,
                  • canuckder
                    • 82
                    So here it is folks!
                    I have a bit of rubbing in the front, but the fender roller will take car of that. so they were 17x9 et.35 and 17x8 et.35, with a 20mm adaptor. with 215/40/17s all around.
                    I guess i could drop the fronts to 205's and it would fix the issue also.
                    • FunfGan
                      • Jan 2011
                      • 4958
                      Looks great!
                      Go here be happy!
                      Ratchet Garage e30 V8 build.
                      • canuckder
                        • 82
                        Originally posted by FunfGan
                        Looks great!
                        Thanks!
                        • grippymonkey
                          • Jun 2011
                          • 759
                          told yah
                          and it looks real good man!
                          GRIPPY'S*GARAGE
                          • canuckder
                            • 82
                            ^^ that you did!!
                            Now we know, vs-xx + rx7 calipers = winnning!
                            Im gonna rent a fender roller this week, ill post pictures again.
                            Ill also post some non-point and shoot photos shortly. I just need to wrap a few registration things up
                            • x17x
                              • Apr 2011
                              • 134
                              looks great man...
