Rota Grid 17x9
  • CrazyB
    • 420
    Rota Grid 17x9
    Anybody know how well this wheels will fit?
    http://cgi.ebay.com/ebaymotors/ROTA-...ht_2206wt_1165
    I am planning on running them with either 245/40/17 or 255/40/17 The fenders will be cut out and flares added. I just need to make sure they will fit as far as on the inner side of the wheel.
    AutoCross Photos!!https://picasaweb.google.com/eugenes18t
  • z31maniac
    • 17566
    You'll need spacers. 15-20mm.
    www.gutenparts.com
    • CrazyB
      • 420
      Ouch so might not be the best wheel for autocross setup
      An suggestions in a 17x9 wheel with okay fitment
      • z31maniac
        • 17566
        Spacers and studs would be OK, just not ideal. Nothing unless you go custom.
        SSR makes a lightweight Lotus 17x9 (like 16.8lbs) 4x100, but would still need spacers and $2200 a set.
        You're best bet is to wait until APEX does the next group buy on their 17x8 ET25 BBS copies, and just run a 235/40/17.
        That will be plenty of rubber.
        www.gutenparts.com
        • CrazyB
          • 420
          Yeah if i go with 235 it is easier to stay with 225/50/15 in a kuhmo v710
          The kuhmo 225/50/15 actually runs .1 inch wider tread that a 235/40/17
          • E30SPDFRK
            • 5713
            Actually you would barely need spacers. The rear will bolt on no problem and the front would clear with a 5mm spacer. You might need slightly larger ones though depending on how far your tires stick past the lip.
            Byron
            Leichtbau
            • CrazyB
              • 420
              Hmm now this sounds promising
              What is a safe size spacer to run on a race care?
              • E30SPDFRK
                • 5713
                Any size spacer would be safe to run as long as you get longer bolts/studs to match.
                Byron
                Leichtbau
                • z31maniac
                  • 17566
                  The wheel maybe, but with a 255? And the deflection that will come under hard use?
                  www.gutenparts.com
                  • E30SPDFRK
                    • 5713
                    I mentioned that he might need larger then 5mm depending on how ballooned the tire is. You quoted it right there.
                    Byron
                    Leichtbau
                    • z31maniac
                      • 17566
                      That was my sarcasm.
                      As your response kind of boiled down to "You won't need spacers that big, unless you run the tires you said you were going to."
                      A 255/40 in any of the sticky tires has an ~10.2-10.4" section width.
                      www.gutenparts.com
                      • CrazyB
                        • 420
                        what would be a good offset to run in a 17x9 with a meaty tire?
                        would et10-15 work?
                        • E30SPDFRK
                          • 5713
                          You forget that a 9" wide wheel measures 10" wide from lip to lip. 255/40's are pretty much square on a 9" wheel. With et15 a 17x9 wheel lip should clear the strut by about 3-4mm, and the strut only gets further away from there. The most he would need is an 10mm, not 15-20 as you say.
                          Byron
                          Leichtbau
                          • dmoney(AB)
                            • 1372
                            Did anyone end up grabbing a set of 17x9 grids?
                            Looking to run them.
                            mtech1/2jzgte/r154/275tire
                            function>form
                            • dmoney(AB)
                              • 1372
                              no one?
                              function>form
