first some background: my bolt pattern is 5x120 in case it matters (i don't believe it does). i am currently running 205/50/16 front and 225/45/16 rear on 16x8 ET23 all around with no (or very minimal) rubbing.
i have 185/60/15 winter tires on order -- will they rub worn on 15x7 ET30 all around? at first i was confident that they wouldn't - 185! - but i recently test-fitted those very same 15x7 wheels wearing 205/55/15 all around, and much to my surprise/dismay, they rubbed. so now i'm not sure.
i intend on running those 15x7s as my winters regardless, so if 185/60/15 will rub, what size tire won't (bearing in mind that there aren't a ton of winter tire sizes available)? from looking around, it appears the other (costlier) option would be 195/55/15. i need to figure this out soon so i know what to do with my order.
thanks in advance.
thanks in advance.
