Tire question and heads up
  • noahp45
    • Jun 2011
    • 107
    I'am curently running 205/60/14 on the rear and 195/65/14 on the front. Is this bad? The rims are BBS weaves.
    1987 325IC all stock
  • ttrousdell
    • Nov 2009
    • 1770
    i would say no as long as both fronts and both rears are the same. just means you have a slightly wider, slightly lower profile tire in the rear.
    The Build:
    • noahp45
      • Jun 2011
      • 107
      So I should get some 195/60/14 for the front?
      • ttrousdell
        • Nov 2009
        • 1770
        not necessary. like i said both fronts have to be the same and both rears have to be the same.
        The Build:
          • 37832
          That setup is fine.
          As said, the 205/60 is .3" shorter in overall diameter than the 195/65. Not something you're really going to notice.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
