17x9 et22 will these fit the rear of an e30?
  • CrusherCurtis
    • 2532
    Will these fit the rear of an e30? No coil overs to adjust camber. I also read that you can't roll the e30 rear fenders.
  • jaywood
    • Jul 2010
    • 4528
    Where did you read that?
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      LOLOL, can't roll the fenders of an E30? I'll put money on it that 75% of R3V members have rolled their fenders by virtue of a baseball bat.
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • FunfGan
        • Jan 2011
        • 4958
        End of a racing jack handle
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • plmichal
          • 718
          Originally posted by funfgan
          end of a racing jack handle
          this.
          1990 325is Brilliantrot/Natur
          • CrusherCurtis
            • 2532
            I read in a couple of treads that rears have seam sealers and aren't welded so it couldn't be done, however I'm sure I'm wrong. I know nothing of rolling fenders. Anyone with opinoins on the wheels fitting? or testimonies?
            • Stephen
              Шлем ишака
              • 10774
              You can roll the rears just fine. Make sure theres no shit stuck in the lip or sever rust before you start
              • Stephen
                Шлем ишака
                • 10774
                Also im running 17x9et10 in the rear. Itll have more to do with tire size and ride hieght than anything, the wheels themselves wont hit.
                • Holland
                  • Nov 2008
                  • 7212
                  That would be correct, but rolling isn't the issue, it's the pulling.
                  Originally posted by DEV0 E30
                  • Nick325is
                    • 1409
                    I have 17x9 et 25 wheels in the rear of a late model e30 with a slight fender roll and they fit fine.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      the height of your car and tire size will be the deciding factors. A roll is unavoidable either way.
                      Taylor
                      • einstein57
                        • Jun 2007
                        • 10780
                        You can roll even with the seam sealer. Its just not optimal. Scrape or wire wheel it out and then roll pancake flat. That wil be $5 kind sir.
                        www.gecoils.com
                        • tito12121
                          • Nov 2016
                          • 33
                          What did you run up front? What tire size did you run? I know this is old hopefully looking to get info since I plan on a set of 17x9 et 25 wheels all around.
                          • martinezduanejr
                            • Mar 2018
                            • 1
                            Would really like to also know what tires y'all ran, getting a pair of 17x9 et 25. Would appreciate the help!
                            Sent from my Z983 using Tapatalk
