Will 17x9 et20 Fit?
  • Jajabis
    • 6
    Will 17x9 et20 Fit?
    I'm looking to pick up some rota grids, 17x9 et20 All the way around. How well will they fit? Do i need a spacer?
    Thanks.
  • Eric
    • 5142
    no.
    • HR2L
      • 724
      I'm running 17x8+20 Grids on my e30 with no issues (no spacers). Rota doesn't make the Grid however in 17x9 4x100 only 4x114.3 if i'm not mistaken. Unless your running a 5 lug conversion and are going 5x100 then your all good, and there should be no fitment issues (other then having to run a stretch tire and some aggressive fender rolling).
      • jaywood
        • Jul 2010
        • 4528
        10mm spacer? I thought et10 was the only size that fits with a 9"
        • Nick325is
          • 1409
          I've got 17x9 et28 on my late model e30 with no rubbing.
          • Massimo
            • Jan 2008
            • 3207
            I know some Japanese wheel manufacturers will let you buy pre-drilled wheels that way you can have what ever stud pattern you want.
