4x108 PCD?
  • Aus E30
    • Jul 2009
    • 478
    4x108 PCD?
    [Thanks all]
    Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
    I <3 dead naked girls.
  • LivingLegend06
    • Dec 2006
    • 1604
    No, of course they wont be direct fit if they are 4x108. You will need adapters to run those ugly ass wheels. adapters would be ideal since you would still need a 20mm spacer even if you went the fill and drill route.
    • einstein57
      • Jun 2007
      • 10780
      Unless you have an ix you probably won't be able to fit et40 wheels regardless of the bolt patter. The inner edge will rub the strut tube. I'd get these in 1.25" thickness.
      www.gecoils.com
      • Holland
        • Nov 2008
        • 7212
        Final et of 20 or so, with adapters would be about ideal, if it's an 8 inch or so wheel.
        Originally posted by DEV0 E30
