4x108 bbs?
  • Chaz
    • Jul 2011
    • 432
    4x108 bbs?
    I found a set of 15inch 4 bbs wheels that look just like basketweaves with bolt pattern on 4x108 on craiglist. I offered to trade an extra set of bottlecaps plus $50. Would adapters like these work?
    Also here is the ad.
    Thanks
  • Nsquared97
    • 1656
    Ad says:
    Vehicle Side Bolt Pattern 4x108
    Wheel Side Bolt Pattern 4x100
    You want the opposite of that.
    • mkcman17
      • Jul 2010
      • 8240
      yeah my buddy is running 4x108s on his vert via adapters. they look high enough offset to not cause any interference issues, plus they're the same width as bottlecaps.
      still, it's going to cost $75 + ~$300 adapters + tires.
      so unless you plan to run used rubber, it'll cost you closer to $700 to run those wheels.
      worth it for a 15x6?
      1989 LN106 Hilux / 3.0TD SFA
      1974 2002tii / stock
      2002 IS300 / 5spd LSD
