Cheap ways to reduce unsprung weight?
  • tk-421
    • Sep 2011
    • 291
    What's a cost effective wheel/tire set that would make a big difference in unsprung weight vs OEM (i.e. bottlecaps)?
    1990 E30 325i sedan - Gletscherblau (280) over Indigo cloth (0271)
  • 325ix
    • Aug 2009
    • 7783
    TRM C1's from tire rack.
    • FunfGan
      • Jan 2011
      • 4958
      Add some dunlop dizezza star specs and you'll be very happy. The Dunlops are fairly cheap and incredibly grippy. Drive the hell out of my car even in the rain, and I have yet to even get the back end to feel light.
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • iamsam
        • Jun 2008
        • 173
        remove brake calipers
        • einstein57
          • Jun 2007
          • 10780
          konig wideopens 15x8 et20. Look much better then C1s, Tons of lip, lots of finish options available and are lighter at 13.6lbs.
          http://www.good-win-racing.com/Mazda...t/21-1014.html
          www.gecoils.com
          • Sagaris
            • Sep 2009
            • 2243
            Nice to see people on R3V that value performance over "fitment".
            -I am not a fan of cross-drilled rotors, but they should provide a slight decrease in mass.
            -Run a smaller tire size
            • einstein57
              • Jun 2007
              • 10780
              BBK should help if your financially inclined. Those aluminum calipers are pretty darn light. e30 m3 aluminum control arms. Running coilovers with shortened strut tube and shorter stuts. Although if your already running bilstein sports they are inverted. Inverted rear shocks are good. ABS delete so you can get rid of the reference sensors and rings.
              I'm super cheap so i got some drag dr46s. Paid around $712 shipped with dunlop direzzas mounted and balanced and hub rings from discount tire direct. Then i received a $70 visa card.
              Drag DR-46
              15x7 +10 4-100 ~ 2.80" LIP (13.35lbs.)
              Available Finishes:
              Gloss Black with Machined Lip
              Gold with Machined Lip
              Red with Machined Lip
              White with Machined Lip
              www.gecoils.com
              • trackjunkie21
                • Jan 2010
                • 3962
                take springs out, now there are no more springs to be weighed.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • LivingLegend06
                  • Dec 2006
                  • 1604
                  Titanium lug nuts
                  /thread
                  • bmwguy325is
                    • May 2011
                    • 1263
                    Originally posted by LivingLegend06
                    Titanium lug nuts
                    /thread
                    Volk RE30 9.2 lbs
                    OR
                    Like on mythbusters use lumber as a wheel
                    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                    • oxymoron
                      • Nov 2011
                      • 356
                      direzzas are such good bang for buck.
