tie rod ends
Interesting vibration
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348Comment
I thought about doing that, but the issue is finding someone around here that has the ability (and expertise) to do it right. For $300, I'll take my chances on a new set of tires.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Have you tried rotating the wheels from the rear to the front?
I have a small shake too but everything I'm ky front end is solid or hard poly. No rubber anywhere. So i guess my shake could be no vibration dampening parts up front. And 600lb spring rates lol
TaylorComment
True and unbent being the key words here. Even though you've had the wheels balanced that does not mean they are straight. I still vote wheels as the culprit before tires. e30 wheels are known for bending near the lug nuts.
Although it is curious that the vibration does not change when the wheels are rotated. I would think that if it were either wheels OR tires that a change would be noticeable with rotation of the wheels.
Oh? How did you rule out the wheels?Comment
Wheels just don't bend on their own and I haven't hit anything that would cause a wheel to get bent. It has to either be the tires or the wheels and since I'm confident that no damage has been done to the wheels, I'm putting my bets on it being the tires. I'll know for sure if it's the tires when I get a new set, but for now I'm just staying around 65-70 to avoid the shakes!True and unbent being the key words here. Even though you've had the wheels balanced that does not mean they are straight. I still vote wheels as the culprit before tires. e30 wheels are known for bending near the lug nuts.
ChrisYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
