Maybe this could turn into an adapter fitment thread, I really don't care. What I'm really looking for is some e38 style 5s on robs 18/20mm adapters. Haven't really found any great shots that shows how far they stick out and whatnot. Like I said any adapter set ups are cool I'm just really looking for them with the e38 fives! Thanks in advance for the pictures!
The Adapter Thread.
This is a great thread idea, not sure why it wasn't done sooner!
I'm running 4x100 - 5x120 adapters from Rob, 20mm in the front, and 25mm in the rear.
My wheels are 16x7.5 ET38 ACT weaves, putting them at ET13 rear and ET18 front.
Front fitment:
Rear fitment:
Rear hub:
Rear hub (without overlap plug):
This may actually be the perfect place for my question. (well, about as close as I could get...) I have a set of 16x8 et0 and et16 wheels. However they're 5lug and even with the smallest adapters I'd be looking at et-18 and et-2. And that I know pokes like hell. However, I should be getting the dtmfiberwerks fender flares here today or tomorrow(http://dtmfiberwerkz.com/access/rive...res-p-343.html). Their website shows "about 2 inches of flare from stock". Anyone have any idea what thickness adapter I should run?
Go ahead and shoot me if this is just a bad idea.
Edit; Just got the flares and they are pretty big...Last edited by iansane; 02-09-2012, 02:51 PM.84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350
Manual swap all the things!
Originally posted by mr walker View PostJanderson, since you have the adapters and pictures of said adapters, could you explain to me how those work? Is the plug made of steel rather than aluminum? How does the plug attach to the hub?
Originally posted by iansane View PostThis may actually be the perfect place for my question. (well, about as close as I could get...) I have a set of 16x8 et0 and et16 wheels. However they're 5lug and even with the smallest adapters I'd be looking at et-18 and et-2. And that I know pokes like hell. However, I should be getting the dtmfiberwerks fender flares here today or tomorrow(http://dtmfiberwerkz.com/access/rive...res-p-343.html). Their website shows "about 2 inches of flare from stock". Anyone have any idea what thickness adapter I should run?
I was gonna say you should mount the wheels and the flares to see how much space you had but remembered they were 5 lug :( Maybe you could just do a 5 lug swap?
Here's my 17" style 5's with 20mm adapters all the way around. These are the wheels from my s50 car so the tires are 215/40-17 which is a little too big for use with the adapters. I'm not running these, just was test fitting with them.
"Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
1988 M3 - Track Rat
1989 325iC M50 Vert
1989 325i Coupe
1991 318is
1995 318ti Club Sport
2006 330i e90
2008 Tundra Crewmax
