Mini Cooper S 17in wheels on 91 E30 4x100
  • fixedsix
    • 66
    I bought these 4x100 MINI COOPER S wheels with a hub bore of 56.1 for mini. BMW/VW use 57.1. So the wheels don't fit unless I would run a hub centric spacer to clear the hub pilot on the BMW, then attach the wheel.
    The wheels look better with a 10mm-20mm spacers because mini wheels have around a 40 mm offset. The pictures below show the wheel attached with around 10mm spacer. This was just a test fit. Does anyone think this would be a problem? Thoughts? Ideas?
  • poopin04
    • Jul 2010
    • 1396
    I've always wondered what these would look like on an e30. Not bad!
    Click here to leave me feedback on our transactions. :p
    • KenC
      King of Kegstands
      • 14396
      Those look terrible. So your spacer necks down to the mini hub bore?
      Originally posted by Gruelius
      • fixedsix
        • 66
        The spacers on the car are the cheap autozone type (no necks). This thing is a euro beater. I paid $140, for wheel and tires. I was going to paint them up. Of course I rather have a nice set of old school BBS mesh.
        • KenC
          King of Kegstands
          • 14396
          How are you centering the wheel?
          • 325ix
            • Aug 2009
            • 7783
            You need centering rings. you will get bad vibrations without them.
            ^beat me to it
            • CreamBeam
              • 223
              i was wondering how these would look and they look a lot better than i thought they would, might tlook good painted black also
              • fixedsix
                • 66
                I put spacers on which go past the vehicles hub pilot, so the wheel is only attached with the lug nuts, ( there is NO interfence with the wheel hub bore and the hub pilot on the BMW) I have a stud kit in the front for this test fit.
                I have not driven the car like this. I might not use the wheels at all on the e30.
                • fixedsix
                  • 66
                  I agree the wheels need to be painted, so they don't look like mini wheels.
                  • KenC
                    King of Kegstands
                    • 14396
                    Your wheel needs to be perfectly centered. Sliding it over studs isn't aligning it properly. It's going vibrate like crazy from being off a mm or two and probably shear your studs. Don't drive it like that.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      It actually looks pretty good, A machine shop can bore out the center by a MM and you'll be good to go, was going to do this when I still had my S-lites
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • fixedsix
                        • 66
                        Understood so I guess I should just get a set of the ESM BBS reps huh? and save these wheels for my R53........
                        The safest option would be have them machined to 57.1 and get some H&R 15mm spacers which would cost too much.
                        • KenC
                          King of Kegstands
                          • 14396
                          You can pick up hub centric spacers pretty cheaply. I sold a set of used ones with extended lugs for like $150 a year ago.
                          Shouldn't be too much to machine them either, but I agree you should just get the ESM reps.
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            those look amazing. I might have to jump on a set for sale locally. The set plus pretty good condition tires is 200$.
                            The offset is 48. pretty crazy.
                            2014 Alpine White 335i MSport
                            (Daily Driver)
                            Full Mperformance Aero
                            KW V2 Coilovers
                            VRSF Catless Downpipes
                            • Wh33lhop
                              • 11705
                              You may be able to pick up a set of custom adapters with a 57.1 bore on one end and a 56.1 on the other. But again, that would probably be a few hundred bucks.
                              paint sucks
