chikara RS7
  • lovinmye30
    • 117
    chikara RS7
    The rims im looking into buying tax time. offset is 20, 15X8 would that be flush on a early e30? my cars petty low but i dont think low enough for stretching ): so would run probably a 195/45-50-15 what do you guys think? i think that would stretch a little. the rims are stock bottle caps right now. so im thinking 15 inch would fit nice, cheap tires. any pictures of these rims on a e30 would be excellent or same wheel specs(offset and size)
  • FunfGan
    • Jan 2011
    • 4958
    Those are going to be pretty stretched depending on what tire you get.
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • lovinmye30
      • 117
      i want a slight streach but if i do that are the tires going to be alot smaller in height i want the tires flush tucked under the wheel well. may need bigger tires.
      • FunfGan
        • Jan 2011
        • 4958
        You'd need to be absolutely slammed to pull off small tires on a 15" wheel. I had 15x9's with 205/50's and even with my skid plate 1" away from the ground I was tucking maybe 1cm of tire in the front. Its just difficult. You could definitely run some nice, chunky rubber on those though.
        Go here be happy!
        • lovinmye30
          • 117
          yeah i found a pic of what i want but it looks too big to fit in my wheel wells.
