Correct tyre pressure
  • Inkar
    • Feb 2011
    • 41
    How much air should i put in my 16x9's with 205/45/16 tires?
  • FunfGan
    • Jan 2011
    • 4958
    I ran mine at 38psi cold, hot psi probably won't matter to you though.
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • Inkar
      • Feb 2011
      • 41
      Thanks bud
      • FunfGan
        • Jan 2011
        • 4958
        No problem man, just make sure you check the temperature after you've driven around for a bit, you may need to lower it down to around 36psi or so. Just don't want it going much higher than say, 42psi.
        Go here be happy!
