17" Style 5 Refinishing Progress. pics
  • navid41691
    • Apr 2011
    • 677
    A little pictorial of my progress on these style 5's. Centers and bolts are in the process of being powder coated by Dave at Renewed finishes. He's an awesome guy to work with and more info about him and his services can be found out through Levent at GPS.
    Right after stripping
    Started the sanding process at 600 grit
    Almost there but not quite
    Wheel 1
    Wheel 2
    Wheel 3
    Wheel 4
    Sanding process on all four wheels 600>800>1000>2000>3000>Neverdull (sucks)> blue magic metal polish (works okay)> white jeweler's polishing block + polishing wheel on a drill is what really got it to that mirror finish.
    I will post pictures of them when they are all together with the centers!
  • einstein57
    • Jun 2007
    • 10780
    Mothers aluminum polish. (the paste)
    www.gecoils.com
    • Jszy25
      • 352
      That Neverdull stuff only works on already fully polished surfaces and even then, it still sucks. Waste of money.
      ^Also, the mother's alum. polish will only get you so far. You need more cut when polishing something for the first time.
      The ONLY way to get a proper finish is with a cotton sewn wheel + black/brown/white rouge compounds. I mount 6" sewn wheels on a 10k rpm grinder. It works well for polishing, but you'll get filthy dirty and its dangerous so be extra careful.
      Nice job on the style 5's...I've done two sets now and I'll never do another. Such a PITA.
      91' 318is - OBDI M52/ZF swap w/ S50 cams
      • yanal
        • Jun 2011
        • 248
        Mothers aluminum polish worked great for me
        Sticky:True e36 one touch windows DIY
        1990 M3
        1992 Mtech (S50 + 5 Lug)
        • Jszy25
          • 352
          no offense, it just looks a bit dull to me. If it had a proper cut on it, it would be a mirror, not just a blurry reflection. Again, no offense.
          • yanal
            • Jun 2011
            • 248
            Non taken, but it's a cell phone picture
            1990 M3
            • svn2002s
              • Sep 2004
              • 486
              What do you use to fill all the dent/scratches/curb rashes that show on the pics?
              • navid41691
                • Apr 2011
                • 677
                10k rpms does sound dangerous haha. but your wheel looks really good.
                Most of the scratches were just chips of the clear coat so after stripping it away I was left with some minor ones that I just sanded down and tried to just make the aluminum flow. No filler or anything was used. Just sanded them down.
                • einstein57
                  • Jun 2007
                  • 10780
                  One of the places i buy my powder coat supplies from sells a metal filler. You build it up like body filler except its designed to take the heat of powdercoating. Its a little pricey at $30 a can but cheaper then buying another wheel just for the center.
                  Discover the ultimate destination for powder coating enthusiasts. Powder Buy The Pound offers a wide range of premium powder coating supplies and equipment, ensuring you achieve the best results for your projects.
                  www.gecoils.com
                  • infanterene
                    • Jan 2011
                    • 146
                    I am in the middle of this same project. I hope mine come out as good as yours.
                    I'm not a real car guy :(
                    • cbouchez
                      • May 2007
                      • 2789
                      Very nice job, the tires where never removed?
                      Follow my IG @bouchezphotography
                      • navid41691
                        • Apr 2011
                        • 677
                        no i never got the tires removed, I was trying to save money =/
                        finished wheels in sig!
                        • tech54K
                          • Sep 2017
                          • 6
                          Good job in powder coating your tire. Looks professionally done.
