Spacers on a e30?
  • Ludey849
    • May 2011
    • 58
    Spacers on a e30?
    Just got RS's for my e30 which im going to be slowly building.
    Their 137's which im going to be getting new lips for.
    Finished specs are going to be
    F: 16x9 +21
    R:16x9.5 +15
    I just test fitted them and the back has little clearance and front doesn't fully rest of the hub , it hits the full coilover.
    Question is how do spacers work? i was thinking 5- 10mm all around to help with the clearance. But will the spacers interfere with the hub centric rings i got to fit the rs on since the center bore on the wheel is 60.1 and on the hub its 57.1.
    Need some feedback.
  • xphiledan
    • 706
    You can get spacers that is 60.1 on one side and 57.1 on the other side
      • 37833
      Although I am not sure what size spacers you will need you can definitely run spacers and hubcentric rings. I've seen people do it often.
      Grover Beach, California
      BimmerHeads.com
