Am I making a mistake with 16x7.5 Kosei K1s?
  • mspiegle
    • 1026
    A quick check on TireRack reveals only 1 r-compound (a yoko) that comes in the 225/45/16 flavor.
    Is there a better tire place that has a larger selection, or am I kinda screwed with the 225/45/16 tiresize?
    Just an FYI - i don't have the K1s yet, but i'm going to do a few track sessions with basketweaves and street tires. I think by my 4th or 5th track session, i'll get the K1s and r-compounds as a secondary set of wheels.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
  • permit
    • Mar 2005
    • 3363
    16" wheels don't have many tire selections to begin with, so finding any selection of R compounds will be difficult.
      • 37833
      Check www.tires.com aswell
      Grover Beach, California
      BimmerHeads.com
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        um ra1's come in 225/45, and if you're a balla, 245/45
        • cheades
          • 632
          If all you want is 225 width why don't you just put 225/50 on your stock 14" basketweaves?
          • mspiegle
            • 1026
            Why on earth would I do that? They wouldn't fit firstly, and 225/50 is not even close to the stock diameter.
            Michael Spiegle
            '99 M3 / Track Car
            • mspiegle
              • 1026
              I wanted those... but Toyo doesn't claim to make them:
              205/55ZR16 236850 5.5-6.5-7.5 23 8 24.8 8.4 11.4 1235 44 853
              225/50ZR16 236890 6.0-7.0-8.0 23 8 24.8 9.0 11.2 1390 44 853
              P255/50ZR16 236880 7.0-8.0-9.0 27 8 26.06 10.4 11.7 1687 44 815
              245/45ZR16 236800 7.5-8.0-9.0 25 8 24.6 9.6 11.2 1477 44 861
              Where would I get that tire?
              Michael Spiegle
              '99 M3 / Track Car
              • rwh11385
                lance_entities
                • 18403
                tell this to Jay. he's a defender of 16".
                15" have good selection of tires, including 225/50 and 225/45.
                true story. cheap wheels too. this is what Jet H K-prepped guy runs (one of Skafrog's friend's instructor one-time, and we've run into him a couple times now.)
                and read this thread while on the topic:
                esp this:
                I say wait. You might think you're close to the limit, but I'd be willing to bet there's still quite a bit left in most corners that you think you're "max'ing" the car out on.
                I thought I was pretty close to what my car could do after 3-4 schools, but here I am after 9 schools and I'm still getting quicker and quicker, and learning more and more on street tires.
                Just be patient, and get as much seat time as possible.
                If you really want to get a tire that will hold up to the abuse a bit better than the ES100's(I personally think they suck from a wear perspective given their grip level on the track) - step up to something cheap like Kumho MX's that'll give you a hair more grip, handle the heat(which is the biggest thing that gets to people with medicore street tires and trying to go fast), and wear pretty well.
                After this set of Azenis, I'm buying 205-50-15 Hankook RS-2s, then probably a set of BFG KDs which TIATO ran even at his experience level.
                • rwh11385
                  lance_entities
                  • 18403
                  well, unless I was drunk and seeing things, Jet's fit fine. And they are only -4.7% the size of stock, which is a fine undersize. That's the same diameter as Charlie was using with his 205/55-14 RA1's.
                  in summary, yes, i think that 16" wheels aren't as good of a choice as 15's. 15's are cheaper, the tires are cheaper, and tire selection is much larger. including 205-50-15s (both street and r comps), 225-50-15s (street and r comps), and also 225-45-15 r comps.
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    I thought we were only supposed to be in the context of street tires since the entire thread was about his situation as a new racer?
                    Hypocrite.
                    • cheades
                      • 632
                      Yeah, 225/50-14 on basketweaves fits perfect. Just look at what most of the specE30 racers are using, they will work perfect. They are smaller in diameter, but when do you ever get to the top of 5th gear anyways besides on the Ring. If you have a 3.73 they would be perfect to give you essentially a 4.10 ratio for better pull out of the corners.
                      • rwh11385
                        lance_entities
                        • 18403
                        Hypocrite.
                        Jay, both street tires for now has a lot more selection,as well as long down the road there are racing compounds in 15".
                        Stop being a child.
                        • mspiegle
                          • 1026
                          Wow, I stand corrected. Sorry for sounding like an ass.
                          Hmm... this might be interesting with a 4.10LSD...
                          Michael Spiegle
                          '99 M3 / Track Car
                          • rwh11385
                            lance_entities
                            • 18403
                            Don't worry about it.
                            3% and 4.10LSD = about 4.23 which is near what Ted Anthony runs in his racecar. So it might be interesting but will work anyway.
