What offset is ideal for 15x8's? Thanks
Offset for 15x8's
give me about a week and a half and I will let you know.Originally posted by egk2et 13 good or bad?
My bolts are at the shop right now getting chromed, after that's done, it's getting mounted on the E30.~ Go Canucks Go! ~
yah I have RM's.Originally posted by egk2why? you have et 13 15x8's?
Im in the process of cleaning them up, it should look pretty nice with polished lips and chromed bolts.
The bolts should be done next Thursday. Then I will go get tires on the following Monday.
~ Go Canucks Go! ~
My cr7's on 215's are fine, no rubbing but if I were to go 225's I think I'dOriginally posted by MystikalThey'll work with 205s, 225s will be a tight fight on the fenders. Then again your CR7s were too, these will not be that much different.
rub, l don't really want to run 205's, I like the look of my old set up 225/50/15's.
ah in that case you are on your own. I'm running 205s in mine.Originally posted by egk2My cr7's on 215's are fine, no rubbing but if I were to go 225's I think I'd
I'll see how the 205s are, roll my fenders if I need to, and then see if I squeeze in wider tires in the future.
I can't wait to get the RMs on, I've had it lying around for so long because I have been too lazy to clean it all up, I've finally got off my ass and sent the stuff to the shop :pimp:~ Go Canucks Go! ~
all in the process rite now.Originally posted by egk2I remember you were going to sell them to me. Did you fix that bent lip?
~ Go Canucks Go! ~
Okay. You'll be rubbing almost for sure with the RMs, probably need to roll a little more aggressively and/or pull.Originally posted by egk2My cr7's on 215's are fine, no rubbing but if I were to go 225's I think I'd
rub, l don't really want to run 205's, I like the look of my old set up 225/50/15's.Comment
BBS RM only come in one kind - 15x6.5 (et33 i believe).Originally posted by egk2Should I find another set with a more suitable offset, what offsets are rm's
available in?
So if you want to roll in 15x8 RMs, offset is fixed - et13.
You could always run 15x7 RMs or go with 15/16" RS's.~ Go Canucks Go! ~
