looking for some info
  • PFCRayB
    • Nov 2009
    • 403
    i got a set of wheels and am looking for the offset, I'm not sure what make they are, the marking on them are 15x6 1/2jj i can't find anything else on them i will post up pics when i can
    Ray
    Originally posted by Erick
    Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
  • ak-
    • 12422
    Measure it yourself.
    Center of the wheel's hub, to the inside rim.
    1991 325iS turbo
    • PFCRayB
      • Nov 2009
      • 403
      thanks dude, it is in inches or mm?
      • ak-
        • 12422
        mmmmmmmmmmmmmmmmmmmmmmmmmm.
        1991 325iS turbo
        • ak-
          • 12422
          I wasn't really clear tbh.
          Measure your wheel's width(in your case, 6.5inch).
          Divide that by 2. That is the center of your wheel(x).
          Now measure the back of your wheel's hub to the edge of the inside rim(y).
          x - y = offset.
          1inch = 24.5mm
          1991 325iS turbo
          • PFCRayB
            • Nov 2009
            • 403
            thanks dude, i also really want to kno what wheels these are, eventho i am using two of them for my laptop/footrest i am too lazy to take a pic of them
            • PNWDan
              • Feb 2011
              • 1326
              Originally posted by ak-
              1inch = 24.5mm
              uhhh 25.4
              1987 Alpinweiß 325is
              Like the PNW E30 Local Crew Facebook page
              • 2761377
                • Jan 2011
                • 399
                sometimes called backspace, for practicality the dimension will be a function of the measured distance between the outside of the rim lips. a rim officially sized 6.5" will normally measure at least 7" and maybe more. when you measure the distance from the mounting surface of the hub (most easily done with the wheel resting on concrete outside up) to the rim the only point to measure to is the outside of the rim.
                forget the claimed spec of the rim, measure the width outside-to-outside and use metric system for all measurements. since it is conceivable the rim thickness varies inside/outside your measurements could be +/- as much as 3mm.
                hth
                robert w.
