BBS RS 003 + 300mm brake disc and calipers
  • shoguncro
    • May 2011
    • 115
    Will bbs rs 003 16" fit on a E30 with calipers from a 740i and 300m disc
    thanks
  • bimmerteck
    • 762
    RS 003 and 300mm rotors are not really compatible, it puts the caliper against the bolts without pretty large spacers. In general RSs are not a good wheel choice if you want a BBK, unless you want to put small lips on the fronts and run large spacers.
    • shoguncro
      • May 2011
      • 115
      front lips will be 7j et 27 wi can put 20mm whitout a problem
      the problem is the diamtere of the wheel and brakes / discs
      • bimmerteck
        • 762
        My 300mm BBK cleared the barrel, just not the bolts/faces and I wanted wider lips so large spacers were not really an option. 740i's here in the states don't have the same 4 pot calipers the euro models do or I would be happy to drag an RS out of storage and check for you. :/
