15" Enkei et35
  • imprttuner88
    • 293
    15" Enkei et35
    Wanting to know what size spacer to run if its possible on my dads '88 ETA for GS autox? They have 225/40/15 Hoosier A6's mounted up.
    TIA
    Sent from my DROID RAZR using Tapatalk 2
    1987 325i LeChump: H&R Race springs, weight reduction and beat to hell
    2005 Mazda RX8: Koni Yellows, Hotchkis FSB, 245 BFG Rivals RTR #11
    2011 Mazda CX7 Sport: The family truckster
    2001 Buick Park Ave: The DD grandpamobile
    1991 Ford F150 XLT 302: camping/towing
  • imprttuner88
    • 293
    And if I can loan him my rims/slicks for some added grip. His car has H&R sport springs, bilsteins, offset bushings and camber plates fwiw
    • einstein57
      • Jun 2007
      • 10780
      1-100mm depending on the width.
      www.gecoils.com
      • imprttuner88
        • 293
        7" wide rims. These are off a miata
          • 37833
          10mm spacer will be a good fit.
          Grover Beach, California
          BimmerHeads.com
          • imprttuner88
            • 293
            Thanks!
            • einstein57
              • Jun 2007
              • 10780
              I'd go with 25mm fronts and 30mm rears. That should get you pretty flush with minor rolling.
              www.gecoils.com
                • 37833
                Why does everything need to be HellaFlush? 10mm spacers will give a GOOD FIT with his 225 Hoosier tires without rubbing/fender issues at all.
                BimmerHeads.com
                • imprttuner88
                  • 293
                  All we are looking for is function! Wanting to get him out participating in it...
                  • einstein57
                    • Jun 2007
                    • 10780
                    I ran 225/50 Hankooks on my 7.5 Ronal LS' and had to run 15mm spacers on my et 25 wheels to clear the brakes. They did not require any fender rolling up front. For the rear i ran 20mm spacers to have them match the fronts. With minor rolling they were great. Far from "Hella Flush" but i don't know why you'd be against a wider track. Its not like the e30 is so short that it would inhibit performance instead of enhancing it. Kev now tracks my old wheels with the same size spacers and loves it.
                    www.gecoils.com
                    • SeatownE30
                      • 594
                      einstein57 - what brakes are you running? i thought those wheels mount up perfectly to the E30's.
                      1991 318i Sedan
                      2005 X5 3.0i Sport
                      2010 328i M-Sport Touring
                      • einstein57
                        • Jun 2007
                        • 10780
                        RX-7/Corrado BBK
                        www.gecoils.com
                        • SeatownE30
                          • 594
                          RX-7/Corrado BBK
                          I see...hence the required wheel spacers
                          1991 318i Sedan
                          2005 X5 3.0i Sport
                          • imprttuner88
                            • 293
                            Thanks for the replies gentlemen!
