Tire question please help !
  • AldcE30
    • 66
    I just got my rims and I need help ! i am running 17 x7.5 et 35 up front and 17 x 8.5 et 15 in the rear and i need to find the right size tire, i was thinking of running 195 40 17 up front and 215 40 in the rear, im not lloooking for a big pull but a vvery slight pull will be okay. the car is low so i cant put a very wide tire on it. also dont want a very tall tire but not too small to risk bending the rims any suggestions on these sizes? or has anyone done this setup and what ttires did use? also the rims do fit on the front but i want to do a small spacer what size spacer should i run ? 10mm? please help i need to order tires asap so i can do the body work on the car , please respond or pm me , thank you
    Al
    • 37834
    I would run 205/40 front and 215/40 rear. For the front I'd recommend a 15mm spacer.
    Grover Beach, California
    BimmerHeads.com
