Are these BBS rs' worth it?(pictures)
  • mother_russia
    • Apr 2012
    • 421
    Alright so I'm located in Washington state, and I found some dude on the other side of the country selling a set of 4 BBS rs rims. They're real, 3-piece, gold, 16x9/16x8, and I'm thinking if it's a good deal or not. He wants 800 shipped, in PERFECT condition.
    Problem is that the bolt pattern is 5x130. I think they came off of a Porsche or something. So now I'm thinking that if I ever want to re-sell them, would I lose or gain some money back? Are these rims worth it?
  • federal
    • Sep 2011
    • 284
    you can run 5x130/4x100 adapters... on 20 mm. minimun thick. You'll get a very very agressive stance.
    e30 mtech2 cabrio bbs rs
    E30 M3 RESCUED
    Alpina C2 REP
    instragram e30company
    • euronotworthy
      • 111
      I think for $800 it might be worth it to buy them, polish them up, and resell them.
      • flash 23
        • 904
        ^ iirc these usually run a very low offset (maybe even 11mm), if you're gonna run the thinnest adapter (18mm) then that will put you in -7ET.
        looks good, i'd buy and re-drill and get hubcentric rings. or buy em' and sell me the waffles/caps set. :)
        • einstein57
          • Jun 2007
          • 10780
          You can get Porsche adapters for pretty cheap. Let me know if you pass cause i could use them.
          www.gecoils.com
          • ak-
            • 12422
            The offset is 11 from pictures on one of the wheels.
            Regardless if it's an 8" or 9", he's going to pokeeeeeeeeeeeeee
            1991 325iS turbo
            • einstein57
              • Jun 2007
              • 10780
              Yes but i won't
              www.gecoils.com
              • ak-
                • 12422
                Originally posted by einstein57
                Yes but i won't
                Meaty flare vert setup? 8)
                1991 325iS turbo
                • noE30
                  • Jun 2008
                  • 2260
                  I actually just bought a set of high offset rs' in 5x130 16x8.5 and 16x9, i paid $1k and i will be running adapters. If the offsets of those wheels were more adapter friendly then i would definitely say they would be worth it. Offset 11 is a little on the low side for adapters.
                  Flickr
                  @michael.colby on Instagram
                  "All he needed was a wheel in his hand and four on the road"
                  • mother_russia
                    • Apr 2012
                    • 421
                    http://www.racelandus.com/wheel-adap...-adapters.html
                    wow that's cheap. if I get the rims, I'll be definitely be getting these..
                    • Ant_e30
                      • 292
                      or fill and redrill?
                      if they are solid backed you could even just redrill /sleeve
                      • mother_russia
                        • Apr 2012
                        • 421
                        well wouldn't they just lose value if i fill/redrill them?
                        and yeah, they're solid backed.
                        • ZekeTheSneak
                          • 1562
                          Its all about offset and tire size.
                          • mitchlevy7
                            • Aug 2011
                            • 672
                            i just bought the same ones, for more money actually.
                            here is a link with pictures on the po's vert
                            he is running 25mm spacers. you can see that he as some poke
                            for me it will be perfect with a stretched tire ill get the fender lip right between the tire and wheel lip.
                            like they said above, this is a VERY aggressive setup,
                            www.cp-e.com
                            1989 Zinno 325i m52 turbo coupe
                            2015 Ford Fiesta ST, Daily Driver.
                            • homegrone30
                              • Jun 2007
                              • 1449
                              You don't want those. Give me his email so I can let him know how horrible his prices are.
                              Sent from my PC36100 using Tapatalk 2
