Rays TE37-V's or rota Classics?
  • revhead888
    • May 2008
    • 149
    just seeing if anyone has put these rims on their e30 and if so SHOW pics.
    im after some track rims and quite interested in these.
  • e30trooper
    • 11576
    L or LL
    • revhead888
      • May 2008
      • 149
      any te37-V
      i have a feeling for offset purposes and getting nice semislick rubber on them the M style would have to be the case as to not cause massive wheel scrub on the track
      • bmwguy325is
        • May 2011
        • 1263
        Volk Racing TE37V 14x7.0 to 17x10.5 inch 4x114.3, 4x100 and 5x114.3 wheels from UpgradeMotoring.com
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • wakdog
          • 223
          I tried to run a set of Rota Grid-V in 15x8 +0 on my e30 (in sig...) and they have had big issues with brake clearance, had to run an 8mm spacer along with grinding down the caliper...
          Are you buying the wheels in Australia or looking to import? I can give you some wheel suggestions if you are willing to import from the US...
          90 318i M62B44 OBD1
          02 530i Touring (Airlift 3P)
          • e30leigh
            • Mar 2012
            • 481
            with rota's before it got lowered.
            • e30leigh
              • Mar 2012
              • 481
              i ran 16x8's et20 and spaced them. works mint. cos you can get away with a 15mm spacer with no issues. im running 225 in the back too.
              • wakdog
                • 223
                I had a look at the Rays catalogue, for track wheels you would want to run a 15x7.5 or an 8... options would be:
                15x7.5 +25 in S-Rim
                15x8 +25 in S-Rim
                15x8 +0 in M-Rim
                +0 will work but if it has any brake clearance issues, any spacer will put you in negative effective offset...
                If anything I would go 15x8 +25 and then use a 10mm spacer to push it out... Im running a set of 15x8 +10 wheels with 225/45R15 tires on my track car atm and its working well...
                90 318i M62B44 OBD1
