Advice regarding BBS RS
  • Todd Black 88
    • Oct 2007
    • 3449
    I am not sure i understand what you mean.
    For a hub extension, you pop off your hub grease cap, tap the 5mm hub extension that comes with a built in cap in its place. Now your hub is 5mm longer, the same length you lost by your spacer. Now you are back to where you started but the wheel clears the caliper and you have a full sized hub to fit the wheel on. The diameter of the hub doesnt change at all, so if you needed hub rings to fit the wheels you still do, if the hub and wheel bore are the same just bolt them on and enjoy.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • PNWDan
      • Feb 2011
      • 1326
      Oh i see. Yes that is different than what I was taking about. Does it stay concentric with the hub?
      1987 Alpinweiß 325is
      Like the PNW E30 Local Crew Facebook page
      • Todd Black 88
        • Oct 2007
        • 3449
        Exact same od as the hub. I am running them on my m3 to fit my wheels.
        Will probably need to have a machine shop make them for e30 siz hubs though.
        2010 F650gs twin
        • ZekeTheSneak
          • 1562
          Get on the horn with motorsorttech, or adaptec as they were once called. They can machine anything
          • cyrmanj
            • Oct 2007
            • 251
            If the bevel is less than 8mm deep, you will be okay.
            I think I´ll be ok, beveled surface is just 4 mm.
            Thx for the comments.
            e30 diamantschwarz 325i
            http://www.flickr.com/photos/cyrmanj/
