tuck 215 40r16 et0
  • bbmcgee
    • Jul 2012
    • 17
    tuck 215 40r16 et0
    is it possible to tuck a 16 with a 215 40 0 offset on my 318is with a set of sleeve coilovers - will it camber in a lot in the rear once lowered? i have slight rub- i hammer and dolly rolled rears (nicely) .. just curious ... thank you.
  • ak-
    • 12422
    lol, how wide is your wheel?
    Rear will naturally camber a good amount depending how low you go, yes.
    1991 325iS turbo
    • grippymonkey
      • Jun 2011
      • 759
      et0 means nothing if we don't know how wide it is... you can tuck an et0 16x6 all day haha
      GRIPPY'S*GARAGE
      • csermonet47
        • Jul 2009
        • 937
        Also depends on wideness of the tire. With a nice flat roll on my 215/40/16 Ventus HRIIs they didn't rub with an offset of +5 (16x9 wheel), but with my Kumho Ecsta SPTs (same size) they rubbed really bad. Springs also play a part in it. Stiffer setup = less rubbing obviously. I am sure you could make it work. Might need a really slight pull though. I am assuming it is a 16x9 wheel.
        Are Three Vee
        Dad Spec
        • FunfGan
          • Jan 2011
          • 4958
          Of course you are, you stupid stance hipster fgt.
          Go here be happy!
          Ratchet Garage e30 V8 build.
