Tires & Sizing to get the most grip
  • FLG
    • Sep 2011
    • 3165
    I run a set of r1r's
    They haven't seen a track yet as I haven't had the time or money. But running them in the street daily there wonderful, dry or wet. But if used for strictly track or dry days I'd go with a better tire. I needed something good overall as I drive the car a lot. A set of r888s would have probably been better or a slick but than I'd be screwed in rain and also wear out a set of expensive tires very quickly. Also the tread pattern on the r1r's looks awesome just as a bonus.
    Have 225/45/16
    Where in MA are you? I'll be in Halifax later this month and your more than welcome to take her for a spin. Just finishing a boosted m20 swap (320 whp)
    Edit: also be aware toyo tires run a bit wider than there size so make sure you have the room. And noise is no issue, I'm sure you have a decently loud exhaust? It'll probably cover any noise...mine does.
    Only pic I have atm
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • fronton
      • Oct 2009
      • 1262
      Have 225/45/16
      Only pic I have atm
      I also run R1R 225/45/16 with over 300hp and love them. Again, there is NO need for anything wider, especially with less power. If you want 10" wide tires for looks, then reasoning is futile. Just know that you will mostly likely rub somewhere and wonder what you were thinking when you start hydroplaning. It is true that tire grip is not purely a function of contact patch, compound aside. You need heat for grip and the more rubber there is to heat, the longer it will take to deliver the increased grip. You also add unnecessary unsprung weight and get a less comfortable ride with lower profile tires.
      • bubbajan21
        • 1962
        FLG, I very much appreciate the offer, that is very generous and I'd love to get a feel for the R1R's, but unfortunately I am away in Michigan for the next 2 months. :(
        So it seems that the R1R's are not a bad tire based on the two members above who have used them
        Fronton; I am not looking to buy tires for looks and I am also open to opinions. I'm not ignorant and I do listen to what everyone has to say. You make valid points and I've opened up my search options to see what else I can fit without being closed in on 235's or 245's. Thank you!
        • bubbajan21
          • 1962
          Anyone have opinions on the Michelin Pilot Supersport in 215/45 17 in the front and 245/40 17 in the rear? These are the only sizes they make that could work (unless I run 215/45 square or 245/40 square). That's a pretty big spread and I worry about making a car that doesn't handle. Again, I'm not suggesting this is an ideal tire setup, but I'm just wondering if my car's handling would suffer with big tires in back and small tires in the front. I don't want a drag car.
          Otherwise, Michelin Pilot PS2's or Continental ExtrememeContact DWs are looking pretty good. PS2's come in 235/40 17 square setup, and the DWs would have to be the same sizes as above (215 & 245)
          Thoughts?
          • fronton
            • Oct 2009
            • 1262
            Sorry, I came off a little condescending. I have had rubbing issues with 225/45/16 on the fronts and it took a lot of hassle to correct so I don't like recommending wide fronts. I'm also not a fan of staggered setups so that really limits my opinion on rears if the fronts are 225 of narrower. I know you have better front tire clearance than M3s though without the side skirt to contend with so you are probably fine with 225 on ET20 there. R1R does run quite wide. Not as wide as 888s, but nearly.
            • bubbajan21
              • 1962
              http://marktg.toyotires.com/file/30251.pdf
              Not a problem, I know on R3V you get used to dealing with guys who have an idea in their mind, post it, get told it's dumb, and fight it instead of listening to people who have more experience and knowledge than them, so I get where you're coming from.
              I do know without a doubt that I can fit 235/40 17's on the front with zero rubbing (except on the inner frame rail at full lock, but the new car has a TMS steering rack limiter stop kit so it can't hit the frame rail) so that is not an issue. I do know the frustration of buying a set of wheels and tires only to put them on and see they rub.
              I know 215 front 245 rear setup is far from ideal, but will my car handle like a pig in those sizes with the Super Sports? I know I've said it about 100 times, but I'll say it again, I don't want this to end up like a drag car.
              • DTMbimmer07
                • 1485
                I used to run 235-40-15 nitto nt555's up frotn and 245-40-17 nexen n3000 or n5000 i cant remember which one. but i loved it, never had understeer, and driving in the rain was pretty good. rubbed a little bit in the front because im 5lug and i didnt have the right control arms on but wasnt that but i kno if i would do it again it wouldnt rub.
                • Nsquared97
                  • 1656
                  215's up front and 245's out back will defenitely effect handling. IMO sqaure is the way to go, maybe 10mm wider in back, but 30mm is a lot of rubber.
                  Where are you at in MI? Would love to check out your car sometime if your close-ish. Also if your into autoX at all there is an event at MSU this weekend I'll be at. Speaking of tires, I could show ya what 225 R-comps feel like haha.
                  • bubbajan21
                    • 1962
                    I'm in Flint, but I don't have the S50 E30 here in MI, I have my E28.
                    • bubbajan21
                      • 1962
                      Any more input on 235 front and rear PS2s vs. 215 front & 245 rear Super Sports?
                      • einstein57
                        • Jun 2007
                        • 10780
                        Originally posted by bubbajan21
                        If they only made the Super Sports in a 235/40 17 I would rock that setup in a second with the 245's out back. Hmmmmmm, I've got some thinking to do. :)
                        They do
                        http://www.onlinetires.com/products/...5+90v+bsw.html
                        www.gecoils.com
                        • bubbajan21
                          • 1962
                          Originally posted by einstein57
                          That's a cheap federal tire, I'm looking for a Michelin Pilot Supersports tire.
                          • Apps
                            • 175
                            So by this logic, are you saying I'd be able to get power to the ground better via a 215/45 17 Michelin Pilot Supersport than I would via a 245/45 17 Toyo R1R assuming the Supersport has a better chemical compound for grip??
                            Supersport being better than an R1R is a function of the conditions. As I said before heat cycles will change the tire, some slowly some more quickly. This will be a factor in continued traction if you are interested in longevity. I can not tell you which tire has more traction (both longitudinal and lateral) without a set of conditions. This leads into the reason all-season tires exist. American customers in particular want a tire that has a long wear life but can perform adequately in many conditions (snow, ice, dry, wet, cold, hot). This tire is far from optimized for any of these conditions. If you have multiple conditions you would like performance in you will always have a compromised tire. Are you looking for a single performance condition?
                            The logic of "if the pressure and load on the tire stay the same then the area in contact with the road will also stay same" can't be sound because I guarantee you if you have 2 tires with the same compound, same load, and same pressre next to each other, one with a 100mm width and one with a 300mm width, the wider tire will have substantially more grip as it may have the same contact area front to rear in contact with the road, but the width of the contact patch would be ~3 times wider. Aside from chemical makeups of tires, grip is to some extent a function of contact patch and there is no way you can convince me a 100mm wide tire has the same contact patch as a 300mm wide tire. I agree that chemical make-up of a tire is more important than the size of the tire, but to claim that "the amount of rubber in contact with the road does not vary based on size" seems far fetched to me.
                            How can you "guarantee" this. I presented only physics. I do not wish to try to convince you. You are choosing to ignore a physical property.
                            How are you measuring "grip" to say that "the wider tire will have substantially more grip as it may have the same contact area front to rear in contact with the road, but the width of the contact patch would be ~3 times wider?"
                            In fact the tire that is wider will have a wider contact patch (lateral) as you stated but it will also be shorter in the longitudinal direction. The area of contact WILL be exactly the same. a = f/p, force = load (stays the same in your example), p = pressure (stays the same in your example) so area must be the same.
                            • Apps
                              • 175
                              FYI Super Sport is the replacement for the PS2. PS2 will be phased out completely in the upcoming years.
                              The size differences will give you differences in cornering stiffness and in effect the understeer or oversteer gradient of the car. Wider tires in general will have higher cornering stiffness (especially true if the tire line is the same as the structure of the tire internally is extremely similar).
                              You can account for the difference in corning stiffness with sway bars and spring rates to get back to neutral handling. Just something to think about.
                              • einstein57
                                • Jun 2007
                                • 10780
                                Well they make the better one too. Not hard to find. They list all available sizes on federals website
                                http://www.onlinetires.com/products/...g+90w+bsw.html
                                www.gecoils.com
