With re-drill or adapters would these fit?
  • Polaris15
    • Nov 2011
    • 309
    Ughh I'm such a noob when it comes to wheels and tires. Would these fit on my e30? I know i would have to re-drill or run adapters but for $100 it might be worth it!
  • lambo
    Captain Scene Points
    • 10953
    Depends on if the back of the hub is flat or not. Regardless, it won't be worth it imo. Adapters will run you $400 for all four corners and I would guess a redrill is somewhere in that neighborhood as well. If they were E38 or 2 piece 17" Style 5's I would go for it.
      • 37832
      Those are E34 15" wheels, nothing super special.
      They would be best fit with a redrill, I've seen a couple people do this particular wheel.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • ak-
        • 12422
        Yeah they'll fit. Two of my friends done this particular 15"
        Needs a 5mm spacer in the front if you go with redrill to clear brakes.
        1991 325iS turbo
        • Polaris15
          • Nov 2011
          • 309
          Right on. Not doing wheels until spring after paint. I want to restore a set of BMW wheels and stick with 15"s so I'm just learning what it's going to take to run some five luggers on a 4 lug set-up.
