wheel fitment studs spacers
  • limp mode
    • Jun 2012
    • 117
    Ok i know my set up isnt that agressive but i couldnt pass up the wheels they are 16x8.5et15 squared. well my question is how wide of a spacer should i run up front and rear to achieve the sweet spot. ill be dumped on GC complete coilover set up. i was thinking 10 up front and 25 in the rear? Also with those size spacers what size studs should i get? 75/95mm? and tires 205/45 should be a good set up i think 40's on 16's don't have enough meat? The e30 game is a completly different thing for me so
    • 37834
    I am not the expert but I am damn near positive that those wheels will fit with no spacer.
    If you do run spacers (for looks) I'd do nothing more than 5mm front and 10mm rear.
    Grover Beach, California
    BimmerHeads.com
    • limp mode
      • Jun 2012
      • 117
      i will be rolling my fenders and stuff so i want it to poke some in the rear and be about as flush as it can get in the front. :?
      • lambo
        Captain Scene Points
        • 10953
        If you're running a 25mm spacer you need to get 90mm studs. Hell, even with a 10mm spacer I would get 90mm studs. But, for the stance you're looking for 10-15mm Front and 20-25mm Rear should be perfect. Double check with Mystikal, though. He knows his shit.
        • limp mode
          • Jun 2012
          • 117
          haha yea man ill check but thats what i was thinking. thanks
          • limp mode
            • Jun 2012
            • 117
            for tires should i run a 205/45 for this set up with a 10mm spacer up front and 25mm in the rear?
              • 37834
              If you don't want the rear to fit, 25 should be perfect.
              BimmerHeads.com
              • ak-
                • 12422
                Are you positive it's an 8.5"? Are you getting shortened GC's? If so, you're gambling hitting the collar with anything less than a 10mm in front.
                15mm rear is furthest I'd go with a 205/45 since I like my fenders.
                With an early model you can push more in the rear.
                LOL
                1991 325iS turbo
                • limp mode
                  • Jun 2012
                  • 117
                  LOL
                  lol then should i go with a 20 in the rear then/ and i already got shortened GC so yea ill run et0 upfront im sure that wont be an issue with a 205/45. and i just purchased 90mm studs ;)
