Size spacers you recommend
  • semaj4712
    • Mar 2012
    • 3069
    So I am looking to get a set of wheels I ordered to sit flush to the fender with or without much roll needed...they are 16x8 with offset 30...I was thinking about doing 20mm spacers in the rear and 15mm in the front...am I crazy or will that make it sit about flush front and rear?
    29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
    72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
    Gewerkschaft der Polizei Sticker/Clings For Sale $8
  • bmw325csi
    • May 2007
    • 4045
    15 in the from sounds about right but make sure you can squeeze some proper tires on there
    harry/harout
    • semaj4712
      • Mar 2012
      • 3069
      Yea im going to go 215 50 16 on them too
      • bmw325csi
        • May 2007
        • 4045
        I was running 15mm (final et5) on my 16x7.5 and it was perfect. Couldn't go higher that 205/40 though.
        harry/harout
        • ak-
          • 12422
          That's kind of bubbly.
          I'd do 20's all around.
          1991 325iS turbo
          • semaj4712
            • Mar 2012
            • 3069
            bubbly?? 20 you mean 220s??
            @Harry
            Do you think 20mm in the rear will match the front
            • ak-
              • 12422
              215/50 on a 16x8 is kind of bubbly
              1991 325iS turbo
              • carfantiti
                • 790
                I'm getting some et33 I think a 10-15mm spacer should work fine.On my car a et 20 is stock so a 10mm would make it a et 23 which is close to stock.if you don't have wheel studs need to get them.you can use washers as spacers to estimate.
                • bmw325csi
                  • May 2007
                  • 4045
                  final offset of 10 in the rear should be pretty close to the front.
                  Before you actually buy some spacers , get in touch with me and ill let you try my 15mm ones to see how it looks on front and rear then take it from there.
                  harry/harout
                  • semaj4712
                    • Mar 2012
                    • 3069
                    Ok cool will do, I'm not set on the tire fit net yet, gonna look around a bit first
                      • 37829
                      205/50/16 would be the correct size. Run that with a 15mm spacer.
                      Or go 225/45/16 and a 10mm spacer.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • semaj4712
                        • Mar 2012
                        • 3069
                        Ok great thanks, and just to confirm the rears with a 20mm will be good?
