bbs rs replica
  • evilming 6n2
    • Apr 2011
    • 33
    bbs rs replica
    hi all
    i am planning to buy a set of bbs rs replica for my e30 in the following specs 17''/8,5 et20mm will i need spacer to fit them on if yes what thikness should i run to make them fit please?
  • evilming 6n2
    • Apr 2011
    • 33
    bump i guess i will have no help thank for the viewers anyway :(:(
    • madsedan
      • 222
      Everything you'll ever want to know about wheel/tire fitment is stickied at the top of the page this post is on, but I don't know the answer to your question without looking in there.
      '91 318is, S50 swap, Bilsteing/H&R race, Recaro SRD, etc.
      • noE30
        • Jun 2008
        • 2260
        Have you tried searching? There is almost one post a week of someone asking for wheel fitment help. That is probably why no one has replied.
        Try these links as well to compare other setups.
        Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
        ^enter in current specs then enter in new specs and see if they will work out
        Compare your specs to other peoples setup and find out if they will work.
        Once you learn how to figure out wheel fitments it's easier to do with out asking other people, Hope this helps.
        Edit: Just by comparing my setup to what your looking at, it looks like they will fit but you may need a spacer in the front to clear the strut, 10mm or so should be sufficient. But still look around this forum and try figure it out on your own for future use.
        Flickr
        @michael.colby on Instagram
        "All he needed was a wheel in his hand and four on the road"
