Biggest tires to fit e30: rear
  • wenbeaver89
    • Jul 2012
    • 319
    Ok so i have an 87 e30 24v turbo that is gonna need some different tires for the rear so i can hook up a little better. Just wondering what you guys think is the biggest or a good size of tire to run in the rear. obviously the wider and the taller the better!!? Also any input on different tires would be great too. Kinda looking at the nitto gens or the bfg g-force.
    I am planning on running a set of 16in. rota's as of right now.
    I am running eibach suspension so this would be a factor too!
    Also will i need to run spacers or will this not help?
    thanks in advance!
  • kamotors
    • Nov 2007
    • 7102
    every manufacturer is different but you can run 25" tall and around 9.5" wide tread width with the correct offset that hugs that rear shock. With the usual et20 wheels out there you can only fit a 8.5" tread width in my experience. With an et20 8.9" treadwidth, rolled fender, and worn subframe bushings the car was undriveable.
    7speedshop.com
    • wenbeaver89
      • Jul 2012
      • 319
      Ok thanks for your help.
      • wenbeaver89
        • Jul 2012
        • 319
        Any suggestions for a good sticky tire? Kinda on a budget build so any ideas?
        • kamotors
          • Nov 2007
          • 7102
          re070's:)....but not really good for a budget
          7speedshop.com
          • wenbeaver89
            • Jul 2012
            • 319
            ok so my wheels are 16x7 et40 and i plan on running 20mm spacers, do you think i can go wider than 225 or not really?
            • einstein57
              • Jun 2007
              • 10780
              You can run 245/45/16s with 10mm spacers out back and minor fender rolling. Or 20mm and a lot of rolling but no pulling.
              www.gecoils.com
