ESM wheel questions...:D
  • bsturman92
    • Sep 2012
    • 282
    hey so im going to order a set of esm 002 tomoro and i got some questions... i wanna order 16x8 all around but im almost leaning towards 16x8 in front and 16x9 in rear. i am going for a very flush look but i know i will most likely need some spacers. what would some of you guys suggest? 16x8 all around or go staggard?
    • 37829
    Well the 16x8 are ET20 and the 16x9 are ET15. They'll be a direct fit without spacers.
    Spacers would only be for looks and of course depend on what tire size you want to run.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • bsturman92
      • Sep 2012
      • 282
      Well im most likely going to get spacers.I am a big fan of the stretch tire and flush look. But will i need to get a stud conversion? Or will the oem lugbolts work?
        • 37829
        Well it's not like that setup isn't already pretty flush...
        If you're going to run spacers you need a stud kit. Look up Motorsport Hardware in the wheels FS forum.
        Grover Beach, CA
        www.BimmerHeads.com
        • bsturman92
          • Sep 2012
          • 282
          ok i will.. but spacers wouldnt be for a while.. my oem stud bolts will work with these wheels?
          • bmw325csi
            • May 2007
            • 4045
            The rears would be pretty flush and your limited to running 215/40's without rolling your fenders, so I wouldn't put any spacers on the rear if I were you.
            The front could use some spacers but no more than 10mm. You are gonna be forced to run 205/40 on the fronts with that offset though.
            When I had my esm's, they were 16x9 in the rear et20 and that was as flush as it gets. My fronts were 16x7.5 with 15mm spacers and they were flush at et5, however, I was limited to the tire sizes I mentioned above without some serious rolling
            harry/harout
            • bsturman92
              • Sep 2012
              • 282
              Ok awesome a appreciate ur help man!Im ordering them on friday and ill throw some pics up.. and my oem lugbolta will work with these wheels? Wont need to convert to studs?
              • bmw325csi
                • May 2007
                • 4045
                Yes, your lugs will work without spacers. Once you get spacers though, you will need longer bolts.
                harry/harout
