Stripping aluminum wheels
  • IronFreak
    • Dec 2012
    • 3702
    So I have seen it done two ways, chemical and media blasting. What is the best way to go about stripping aluminum wheels? I have some style 32's That I want to refinish for my build and I want to make sure I don't mess up the surface.
    What chemicals could be used that wouldn't eat or weaken aluminum?
    What kind of media would you use in a blaster so it didn't eat the surface or leave a grainy feel?
    Let me know!
    Thanks.
    Instagram @rebellionforge
  • Rockwool2117
    • Jan 2013
    • 143
    paint thinner
    The day I bought my e30, was the day I became sophisticated and classy as fuck.
    • IronFreak
      • Dec 2012
      • 3702
      I don't think paint thinner will strip powder coating very fast........
      • brianao34
        • Jun 2010
        • 660
        I was cleaning some overspray off once with aircraft stripper and had a drop fall on my freshly powdercoated wheels, I wiped it off immediately, and it didn't pull all the powdercoat off, but it did start to eat it away. It would suck, but it's possible.
        I had a set of basketweaves blasted for $75 once. FYI
        But I would blast. Make sure you use glass beads or something that isn't going to pit the aluminum too bad.
        • LJ851
          • 7919
          Aircraft remover takes powder coat off. I would start there.
          Lorin
          The M30 is God's engine.
          • IronFreak
            • Dec 2012
            • 3702
            Cool, It's for the 32's I picked up. haven't decided on color yet but I need then stripped before I can paint!
            • Mr. Tasty
              • Jul 2011
              • 3421
              I used aircraft remover, took off the Powder coat on my gottis
              2014 Alpine White 335i MSport
              (Daily Driver)
              Full Mperformance Aero
              KW V2 Coilovers
              VRSF Catless Downpipes
              • IronFreak
                • Dec 2012
                • 3702
                This^^^
                Or do you guys prefer something else?
                • einstein57
                  • Jun 2007
                  • 10780
                  Aircraft stripper takes forever on powdercoat. Especially since the EPA cracked down on commercial grade sales. I get mine soda ash dipped. Usually cost a little bit more then what you end up paying for aircraft stripper but you don't have to clean up a mess or tend to your chemical burns afterwards.
                  www.gecoils.com
                  • unevolved
                    • Nov 2011
                    • 714
                    If it's just paint, Aircraft Remover is the way to go. It's designed to do exactly that, remove finishes from aluminum without damaging anything but the paint.
                    1991 318i SOLD
                    2003 325i SOLD
                    Racecars and stuff.
                    • cactusjacks1
                      • Sep 2004
                      • 1216
                      +1 - this is the only way, goggle the process for your location.
                      [I
                      • IronFreak
                        • Dec 2012
                        • 3702
                        I did, I'm not coming up with anything. Is this a chemical dipping process?
                        • oliver.r
                          • Mar 2012
                          • 3839
                          If the paint is not peeling or chipping you do not need to strip it off.
                          If it is chipped on some areas you just need to feather i smooth, primer and thats it.
                          Scuff the surface until it is no longer glossy and you are ready for a coat of paint
                          • cactusjacks1
                            • Sep 2004
                            • 1216
                            Yes, it's a huge vat @ 6'x4'x40'. Heres what came up when I goggled So Ca. Maybe some of the key words will help you narrow your search.
                            Welcome to the premier industrial source for Paint Removal & Stripping Services in California - Southern. <!--CITIES--> These companies offer a comprehensive range of Paint Removal & Stripping Services, as well as a variety of related products and services. ThomasNet.com provides numerous search tools, including location, certification and keyword filters, to help you refine your results. Click on company profile for additional company and contact information.
                            [I
                            • IronFreak
                              • Dec 2012
                              • 3702
                              My problem is one wheel has a spot of rash. I'm going to have it fixed but I don;t know how they'll return it to me. I know they'll have to strip the area of the repair. and It's chipping on another wheel as well. We'll see. I found something called B17 on a powder coating site that a lot of guys use.
