Can't find tires in my size
  • CircuitMonster
    • Jul 2010
    • 271
    I was going to pick up some 16x8 16x9 staggered esm002r wheels but I can't seem to find tires in 205 40 16 and 215 45 16 that are made by the same manufacture. Just wondering what you guys are running or who makes tires in that size for staggered wheels.
  • E30SPDFRK
    • 5715
    Why do you want those sizes anyways? The back tires would be over an inch talker then the front.
    I would run a 205/45 all around, or a 205/45 up front and the 215/45 in back if you want to keep the staggered widths.
    Byron
    Leichtbau
    • CircuitMonster
      • Jul 2010
      • 271
      maybe im looking into this wrong then. i thought the height its dependent on the width so if you go wider to even it out your height would change. even still i cant find tires for 205 and 215 with the same model. right now i have 16x8 205/50/16 and they rub a shit load so im scared that 45 will still be to tall. im running bridgestone re760s right now on my old wheels.
      • E30_fiend
        • Apr 2006
        • 7348
        Run a 205/45 all around. You won't rub in the rear with a 205/45 on a 9" wide wheel unless you're absolutely slammed and/or poking.
        • Vivek
          attention whore/retard/bitch
          • 6167
          205/40 is way way way too short for an e30. 215/40 is okay and 205/45 is fine too although they're both slightly small. What's your offsets?
          1992 Mauritiusblau Vert
          2011 Alpinweiss 335is coupe
          2002 540i/6 Black/Black
          2003 GSX-R 750 (RIP)
          • CircuitMonster
            • Jul 2010
            • 271
            i was going to get the esm 002r so 16x8 et20 16x9 et15 im lowered on jom kit right now and the front is pretty damn low my tires are rubbing so bad in the front. again right now im on 16x8 style fives with 205/50
            • CircuitMonster
              • Jul 2010
              • 271
              right now im having the issue of rubbing in the front 205/50 is killing me on 16x8
              • E30SPDFRK
                • 5715
                205/50 is nearly an inch taller then a 205/45, where are you rubbing now?
                You're right that the second number is a percentage of the first, you must have done your math wrong though.
                Byron
                Leichtbau
                • CircuitMonster
                  • Jul 2010
                  • 271
                  right now im rubbing on the top front fender liners again im getting new wheels and i just want to make sure i get the right tires for it and from what ive searched i havent found matching sets for staggered. i dont want to go the stretched look either
                  • einstein57
                    • Jun 2007
                    • 10780
                    I ran 215/40s all around on my 002s.
                    www.gecoils.com
                    • fronton
                      • Oct 2009
                      • 1262
                      then don't run 205 on 9" unless they are r888 which run very wide. Are your front fenders rolled yet where they are rubbing?
                      • CircuitMonster
                        • Jul 2010
                        • 271
                        Front and rear fenders are rolled.
                        • fronton
                          • Oct 2009
                          • 1262
                          Then it sounds like you need a higher offset rim (unless you are running spacers in which case take them off), taller suspension or negative camber.
                          • CircuitMonster
                            • Jul 2010
                            • 271
                            I may raise the front up a little. But I'm sill with the issue of what what company makes tires for staggered wheels I wanted to run the esm 002r 16x8 16x9 but I can't find tires to run for them.
                            • einstein57
                              • Jun 2007
                              • 10780
                              215/40 all around. 7.5" fronts
                              www.gecoils.com
