ideal offset for 15x7 wheels?
    I know BMW's 15x7 for the E30 4-lug is ET24, but is this ideal from the perspective of A) suspension geometry/slip angle, most responsive/neutral/best feedback or B) best lateral grip or C) a compromise of both A and B. Perhaps it's A, then a compromise higher clearance tolerance.
    I may be using spacers to adjust ET on a set of wheels and was ponder whether there is a "better" ET than 24 and if I couldn't make 24 whether it would better to be higher or lower. Would a higher offset be beneficial at the expense of clearance that I don't need anyway? (seems higher offsets are prefered given the higher offset for narrower wheels, and a trend to bias toward less inside clearance with increasing width) or would it be better to go with a lower offset for the wider stance and higher latteral G, keeping in mind that that would require a thicker spacer.
    Do spec series competitor run the lowest offset allowed and fitting?
    Thanks for any input.
    On my early model I run et 11 with a 205/50. There is room for more if you wanted either less offset or more tire. I can't comment of the performance improvement because it was night and day coming from bcaps with worn out 195/60s.
    -Nick
    Originally posted by 87e30
    First of all: calm the fuck down; second of all; cool story bro.
      Which would be better for an early model that would not require fender modifications?
      15x7 et15 205-55-15
      15x7 et20 225-50-15
