Spacers with extended lug bolts
  • lolcantturn
    • 4588
    I have 20mm H&R spacers for my IX wheels and 43mm lug bolts which are the appropriate length. VAC motorsports (where I bought the bolts from) said that this is a very unsafe setup and the wheel should inevitably fall off and to just buy the stud kit....
    I know it's a bit more convenient to mount wheels with studs, but honestly I've only taken my wheels off once in my ownership of my car (1 year) and wasn't too much of a hassle to put the lugs in with the spacers..
    More concerned about safety. Thoughts?
    Originally posted by TSI
    OEM+
  • trippmann
    • Dec 2012
    • 118
    well the positives are that they are hubcentric and you are using the appropriate lugs, to me this is the same as having a properly offset wheel. on the other hand, you are putting more trust on the lugs having the capability to handle the ungodly power that an e30 puts out.
    for a DD i think you would be fine, if you were racing in a top level class i would tell you to reconsider your use of said spacers.
    Originally posted by unloadedak
    It's brand new. I've gripped the shaft a couple times and that's about it.
