looking at some wheels...
  • itsanaudithing
    • May 2013
    • 34
    im running cut springs (P.O) and bilstein sports and i was looking at some 17x8.5 wheels with an offset of 30. would these fit? im not to big of a wheel guy so offsets confuse me!
    Thanks ahead
    87 325iM50 VanosVadersBilstein SportsH&R Springs
  • itsanaudithing
    • May 2013
    • 34
    offset is +30 sorry
    • ak-
      • 12422
      The front will most likely rub your strut housing or brake caliper, which means you'll need a spacer.
      The rear will fit without any modification, but will look a little sunken in.
      Google how to calculate offsets. It's pretty easy.
      Really crude rule of thumb:
      more offset = wheels sunken in
      less offset = wheels pushed out
      Once I learned offset, I use an 8" wide wheel with a 0 offset to gauge how other wheels will fit. Reason being is an 8" et0 wheel sits near flush with a fender with little camber.
      1991 325iS turbo
      • itsanaudithing
        • May 2013
        • 34
        thanks i did that and it helped a lot! what size and offset would you recommend? also the e30 on your right of your sig what size and offset are they?
        • ak-
          • 12422
          It's hard to recommend a specific offset and width without knowing what "look" or what you want to do with the car.
          +20 is always a good offset in my opinion because it lets you play with spacers and tires meaning you aren't stuck exclusively to one tires size or backspacing.
          The black car is 16x9 et0 front et10 rear. The silver one is similar, but with an 8" wheel up front.
          1991 325iS turbo
          • itsanaudithing
            • May 2013
            • 34
            i was looking at something like this:
            http://www.ebay.com/itm/17X8-5-RS-ST...a269d2&vxp=mtr
            not those exact ones. just the bbs rs style and i want 17s to raise my car a little bit
            • ak-
              • 12422
              A proper sized tire on a 15" or 16" should not lower or raise your car, but leave you at factory height with a proper speedometer reading.
              1991 325iS turbo
              • jalopi
                • 2370
                ^-- This website is GOLD for someone in your situation. Punch in the wheel setup you've got now, then punch in for the set you want - shows you a side by side of the two. Tells you how much you're gonna stick out further than your current setup, ect.
