RW wheels 15x7 et30...good fit for the e30? thoughts?
  • Be30riginal
    • May 2011
    • 287
    15x7 et30
    tire size 195/50/15
    will they fit?
    thoughts on the look?
  • JRKOUPE
    • Dec 2004
    • 3159
    not bad.....
    at et 30 you may be a bit close to frt strut tubes.... or rear inner wells....maybe not.
    a 3 mm spacer or so will fix ya....
    205/50 will be better for looks..and correct ride ht...but will cause a bit more clearance issues perhaps.....
    but spacers will fix it.
      • 37834
      Actually a 205/55/15 tire is the correct size.
      As said you may need a 3mm spacer for the front to clear. I'd personally run 5mm all around.
      Grover Beach, California
      BimmerHeads.com
      • Red46
        • 1151
        I'm running 15x7 et30 with 205/55 on all 4 corners
        No issues, spacers would improve the look though.
