Why are my Kopis binding on the brake pads?
  • m20e34
    • Sep 2004
    • 41
    Is this normal? The bottom of the outside front brake pads (side facing hub) is rubbing on the wheel around the circumference of the backside that contacts the hub/brake disc. I hope I am being clear enough.
    I changed brake pads last fall and installed the stock basketweaves at the same time. I just installed the Kopis and now I have this issue. Obviously the problem is the new pads, but they are the correct pad. The only difference is that they are fatter since they are new. Is this something that happens to everyone that I don't know about, or is there another piece to the puzzle that I am missing? I am going to have to dremel the pad backing plates or the wheels unless there is something else wrong that I don't know about.
    FWIW it's a 91 318is.
  • asubimmer
    • 6482
    yep the prob is the kopis...they are terrible. Just send them to me...I know a guy that recycles them and makes coke cans out of them. I'll even send you a few ;)
    btw I wouldn't go dremeling brake pads
    • m20e34
      • Sep 2004
      • 41
      Bad idea, I know. I haven't had the time to check to see how much material actually needs removed to fix the problem. I wouldn't have a problem taking just a sliver off of the backing plate, but if it's bad, I'll have to put the wheels on a mill I suppose.
      edit: for $6500 you can have the Kopis and I'll throw in a free mint 318is.
      • Jand3rson
        • 37587
        Do you have the pads installed correctly? I've never heard of anyone having this problem before.
        • asubimmer
          • 6482
          haha I always give it a shot...one day I will get some alpinas...one day
          • m20e34
            • Sep 2004
            • 41
            I thought there is no way they could be installed correctly for me to have this problem, but after having the wheel off, I don't see how it could be done incorrectly. The pad is located on the brake disc exactly where it should be. I will probably pull the caliper tomorrow morning to investigate further.
            (same problem on both front wheels)
            edit: pads are Hawk HP+, but that shouldn't matter.
            • Jordan325iC
              • Aug 2005
              • 1697
              I'll trade you my custom low-profile duralast pads for your hawks. ;) Only a little bit dusty.
              '88 325is
              VP UT of Austin Autoholics
              BMWCCA 380364
              • NC325iC
                • Mar 2004
                • 6565
                he isnt lying either... he always trys it
                • asubimmer
                  • 6482
                  hopefully someday it will work :D
                  take as a complement ;)
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    Your car is extremely hot.
                    I bring nothing else to the table.
                    • asubimmer
                      • 6482
                      smoked ellips would be HAWT!!11!
                      • m20e34
                        • Sep 2004
                        • 41
                        Yeah, yeah, the car is always a work in progess.
                        I dremelled a sliver off of the pad backing plate, and a little bit all the way around the inside of the wheel.
                        Problem solved. I just can't believe this isn't a common problem. Perhaps the Hawk backing plates are thicker than OEM?
                        • m20e34
                          • Sep 2004
                          • 41
                          It is pretty hot, isn't it?
                          look ma! no sunroof!
                          Too bad my camera isn't so hot.
                            • 37833
                            You bought that car from another forum member didn't you?!
                            Grover Beach, California
                            BimmerHeads.com
                            • DrMcDave
                              • 1793
                              i remember it being for sale
