wheel stud question
  • mathillois
    • Sep 2012
    • 71
    wheel stud question
    might be a stupid question but i was curious if wheel studs got in the way of center caps.
    im looking to do a wheel stud conversion (probably get the vorshlags) and was curious if i could still put on my center caps to my wheel with the stud conversion.
  • mohamed...
    • Oct 2012
    • 577
    if you get the correct size studs yes. also i would recommend going with motorsport hardware studs.
    E30 M30 B35 Swap Mounts!
    http://store.garagistic.com/ocart/e3...=5475809a87e04
    • mathillois
      • Sep 2012
      • 71
      im thinking of getting the vorshlag 75mm wheel studs. will those get in the way of center caps?
      are the motorsport hardware studs stock hex or does it require a key? looking for something thats well built and uses aftermarket key for security purposes.
      are TUV approved Studs any better?(http://www.e30tech.com/forum/showthread.php?t=105758)
        • 37832
        Buy from Motorsport Hardware. Ryan is also very helpful and can answer questions for you. You're asking us if studs will get in the way of center caps but we don't even know what wheels you have. Motorsport Hardware has a variety of lug nuts available including wheel locks.
        Street and Race Wheel Hardware Super Store Performance Wheel Studs Lug Nuts Bolts & Spacers BMW Mini Porsche Lotus Mercedes Audi VW Ferrari & Lambo
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • mathillois
          • Sep 2012
          • 71
          i have a set of borbet type A's and factory e30 BBS rims. will 75mm studs get in the way of the center caps for both rims?
          • FLG
            • Sep 2011
            • 3165
            Talk to Ryan at motorsport hardware, the man is just great.
            Don't quote me but i believe the max (with no spacers) is 57mm to still clear caps.
            Also he just rolled out some new steel forged nuts, they're awesome.
            Sent from my SCH-I545 using Tapatalk 2
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • mathillois
              • Sep 2012
              • 71
              thanks for the info! really helped
