Toyo Proxes T1R - 225/(45-40)/16 on 16X7.5 et20 possible?
  • mk-ultra
    • Apr 2004
    • 22
    i'm buying new wheels and i want to know if someone runs a 225 on a 7.5 et20 wheel, i know it will involve rolling. I might go with a 225/40 to help stuff them under there
    i know et25 is optimal but the alpina kopis come in 17X7.5 et20 so i bet it's not that bad
    and any bad things about the T1R?
    thanks
  • Jordan
    • 12916
    225's will fit a 7.5 wide wheel fine.
    do you have a early or late e30?
    https://mtechniqueabs.com/
    • mk-ultra
      • Apr 2004
      • 22
      91 - late arches
      my concern comes from the offset
      • Jordan
        • 12916
        If its lowered on soft springs its going to rub.
        If its lowered at all its likely gonna rub.
        • mk-ultra
          • Apr 2004
          • 22
          car is lowered but pretty stiff
          even with 225/40 which are 23mm shorter in diameter than a 225/45 you think there no chance at all
          • Jordan
            • 12916
            Stiff like what? Thats very subjective.
            Spring rates?
            Don't go with tires so undersize in diameter. it looks ghey.
            • mk-ultra
              • Apr 2004
              • 22
              yeah i know it's very subjective, but i don't have the rates when i asked koni bout that they told me that the were progessive and didn't had a specific spring rates for them...bullshit
              if it looks ghey or not...is not the question :D
              • cheades
                • 632
                He might not rub, I have H&R race on my car with 225/50-15 on 15x7 et20.
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  225/45/16 will fit fine. Worst case scenario, you'll have to flatten the rear semi-rolled fender lips slightly.
                  But get Hankook R-S2's. They're better than T1-R's in everything but wet, performance-wise that is.
                  • mk-ultra
                    • Apr 2004
                    • 22
                    thanks mystikal, i'll give it a try unless someone tell me from real life experience that it won't fit.
                    I'll check those hankook if they are if they same price range of the t1r, but the place where i'm suppose to buy them only have 3 tire in 225/45-16
                    • Mystikal
                      • 9602
                      They're a lot cheaper, last time I checked.
