I bought a set of wheels, and they seem to require a set of spacers. Before I start acquiring all the parts, I think it'll be nice if someone can show me their setup.
Anyone Running 15x8 ET37?
Tags: None
They will rub the strut tub up front at that offset. Probably going to need 15mm minimum depending on tire size
-NICK -
If I slap on the 15mm spacers, how much would it stick out? Would it be rubbing or just flush?Comment
Can I use 12 or 13mm spacers? Im trying to find a way to make them fit with minimal sticking out of the fender.Comment
Instead of relying on others, you could learn how to figure it out yourself. I've attached some links that will help get you started. Once you figure it out, you'll thank yourself over and over.
Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
Ive clicked on more than half of the google link. Im not too good at this wheel offset fitment checking.Comment
