I finished sealing up a set of RSs a few days ago and finally got a tire mounted to all 4 of them. One of the tires didn't hold air for more than 2 minutes. Another one takes a few hours to lose all the air inside of it. Fortunately, the other two seem to be fine at the moment, but they've only been on for a day, so we'll see if they hold air. But if I did it way wrong the first time, I'd rather redo all of them the right way.
The way I did it the first time was a bead between the faces and barrel. Put the lip on, torqued all the bolts, and laid down another bead 'inside' where all 3 meet (there's not really a "valley" because of the lip). Then another bead a day later.
My only guess to do it properly would be a bead between the barrel and faces, another between the faces and lip, torque everything down, then a final bead where they all meet on the outside. Then go over the final bead again a day later. I'm just worried that it would leak again.
I can't really go the route of dry assembling followed by seal with these so someone could help out, that'd be great :grin:.
