stock bottle caps need tires, suggestions?
  • bendjeff
    • May 2014
    • 80
    I just aquired an 86 325 and the tires are bad (sat for too long). the tires on the car are 215/60/r14. I am wondering what the best size tire is to run on the car. currently it is on stock suspension and has the OEM wheels on it as well. just want a nice tire that is sporty and not $$$. I searched for the 215's and noticed there were only 1-2 options. thanks for any help you can provide!
  • mkcman17
    • Jul 2010
    • 8240
    Stock size is 195/65. 215 is a bit much, 205 is probably the most tire i'd try and fit on a x6
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
    • Dakotademon7
      • Jan 2014
      • 446
      You can also go with a 205/60/14. I plan on doing 195/60/14 on mine. It's just a tad smaller diameter then stock.
      sigpichttp://www.germanaudiospecialties.com/
      1986 325es :early:
      • bendjeff
        • May 2014
        • 80
        thanks guys. that was going to be my next question if I went with 205. thanks for the quick replies. anyone recommend a good sport tire in that size? I bet there are not a lot of options in that size either. tirerack has one kind of tire for it and it is a race tire... hmm
        • goldenbb
          • Jun 2013
          • 208
          I have 205s on the stock bottlecap 14s, they are fine. Alloy 4x100s are fairly cheap, so you could look at buying new 16s in order to get a wider (larger assortment of) tire selection.
          '90 zinno 325iS
            • 37833
            Just go with stock 195/65/14 tires. Falken 912 is a good cheap option.
            Grover Beach, California
            BimmerHeads.com
            • danix
              • Jan 2014
              • 151
              I have been unable to find an H rated tire in the stock 195/65-14. 912 would work but no one has stock and I bet they are discontinued.
              1988 325iC SOLD
              1985 524td 49k
